Badger5Volks Autos
Results 1 to 20 of 20
Thread: DV replacement
    hamski's Avatar
    Sep 2005
    UK
    116
    DV replacement
    I haven't got a clue what DV is on my car. It's not an original Audi one (has splines all round the body). If I'm changing it, do I need to do anything else (remap etc)?
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: DV replacement
    why not speak to QST as they may have fitted it for a reason?
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    Re: DV replacement
    Why are you changing it? If its knacked you can get service kits for them
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    Didn't realise that. I really need to stick a replacement in. Had a noise which I thought was the wastegate. Turned out that it's fine, so next to check is the DV I believe. I'll speak to QST first who would have supplied it.
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    Re: DV replacement
    Why not try fitting a standard one for all that they cost
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    What's the score if it's not up to the job? Is there anything bad that could happen?
    nervus's Avatar
    Apr 2004
    1,155
    Re: DV replacement
    Get a Replacement Bosch OEM one from a dealer they are around 20 and stick that on.
    A DV functions in a similar way to a dump valve except instead of dumping the boost gas e.g. on a gear change it re diverts it back into the charge pipe and therefore is meant to help re-establish the boost pressure quicker after said gear change.
    It could be potentially harmful if the piston siezes and no excess boost pressure is able to escape but it is unlikely that it could fail in that way. Most commonly they fail by rupturing the seals in which case they have a delayed action or dump too much or dont divert back to the start of the loop. Get an OEM and see if the noise goes and if it lasts great! Buy a spare and keep it in the dashboard takes 10 mins to swap.
    Surely someone lived close by that can help you with this, where are you from?
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    Live in Somerset, work in Bristol. Thanks for all your help. I'll see if I can pick one up on the way home
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    Spoke to Bristol Audi. Parts guy didn't know what a diverter valve was!!! He reckons I need a pressure valve???
    Jun 2004
    Crowthorne, England
    2,512
    Re: DV replacement
    Don't get a standard one, the Big Turbo may have relocated the DV etc. Speak to QST from my brief chat with them they'll be very helpful over the phone if you can get through to them.
    If it was a standard car I'd say just fit a bosch OEM one - the part number is 06A 145 710N but like I said it's not a standard car so we shouldn't be suggesting that IMO!
    Nov 2004
    Tonbridge, Kent
    912
    Re: DV replacement
    If it is from QST then it will probably be a Hyperboost Diverter valve. Got mine from there. It is a piston one and should be serviceable.
    rob
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    Spoke to Kim @ QST. he reckons it won't be the DV, but obviously wants me to take the car in. It's a load of hassle, as I'm in Somerset and he's in Haywards Heath!!
    PaulS3's Avatar
    UK
    1,003
    Re: DV replacement
    sounds like a hyperboost as mentioned.
    ie aftermarket DV.
    and if it is then its serviciable if you get the kit.
    Jun 2004
    Crowthorne, England
    2,512
    Re: DV replacement
    [ QUOTE ]
    [/ QUOTE ]
    I know it's a pain but I bet he'll get it sorted straight away if you do take it back and I'd have thought it'd be worth the piece of mind taking it over there?
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    Re: DV replacement
    MTM 330 and you're not sure what the DV does!
    Sounds like you have more money than sense!
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    [ QUOTE ]
    [/ QUOTE ]
    Bought the car already modded. My mechanical knowledge is admittedly poor, but surely that's what these forums teach!!
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    Re: DV replacement
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Apologies... you obviously have money and sense... i.e. buying a car which has already been modded! [img]/ubbthreads/images/graemlins/ok.gif[/img]
    Apr 2003
    s.wales
    363
    Re: DV replacement
    Hamski, What does this sound 'sound' like ?
    Chris.
    hamski's Avatar
    Sep 2005
    UK
    116
    Re: DV replacement
    like a rasping on acceleration. Between about 3500 and 4500 rpm only on acceleration. It's intermittent, but I hear it prob 90% of the time.
    nervus's Avatar
    Apr 2004
    1,155
    Re: DV replacement
    [ QUOTE ]
    [/ QUOTE ]
    Doesn't matter if its modified or the DV has been relocated. If a Hyperboost DV fits then so will a standard one and fitting one as a temp will show if the symptom goes away or not.
    For the sake of 20 its better than farting on going to QST and having your eyes ripped out.
