Volks AutosBadger5
Results 1 to 9 of 9
    darko's Avatar
    Dec 2004
    london, uk
    272
    Adjusting Rear Camber / Toe on S3 !
    seems it is possible on the TT so must be possible on the S3 ? The diagram seems to suggest a special Audi tool is required although these guys: http://www.elite-design.co.uk/ say they can do it. So.. can we finally sort out the inside edge tyre wear issues without adjustable tie bars ?
    darko's Avatar
    Dec 2004
    london, uk
    272
    Re: Adjusting Rear Camber / Toe on S3 !
    how do i post this diagram !!!
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Not sure what diagram you're referring to, but in order to adjust rear camber on the S3/TT you need to have the adjustable rear tie-arms. Forge and ECS make them for about 250-300.
    Not sure if you'd want to be messing with the rear toe angles.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Toe is...apparently with the special tool.
    Camber is not.
    [ QUOTE ]
    [/ QUOTE ]
    Toe can definately be done...as mine was, by the local Audi dealer.
    [ QUOTE ]
    [/ QUOTE ]
    No...sorry.
    If it's lowered, even with the toe set back to factory...you will still wear the inside edges. The only way to cure that is to fit the adjustable arms.
    Imola S3 has some for sale...it might be worth PMing him.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    I certain do have a set for sale.
    My adjustable tie bars + cash for you OEM tie bars.
    PM me with your offer. New price is 299 + vat.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    You sure you've got that the right way round Grant?
    Adjustable bars and cash...for standard?...that's a hell of a deal!!
    Wouldn't standard bars plus cash for adjustable bars, be a better deal for you!! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    As always... you are correct Glen! [img]/ubbthreads/images/graemlins/lol.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    darko's Avatar
    Dec 2004
    london, uk
    272
    the audi document is titled rear axle camber adjusting - not that audi should be trusted to call these things what everyone else calls them [img]/ubbthreads/images/graemlins/wink.gif[/img]
    if someone can tell me how to post the doc ill get it here for all to see
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,093
    IIRC from a post ages ago, the adjutment is very minor... not enough to take rear setting back to OEM state after lowering.
