    Yohan87's Avatar
    May 2011
    405
    312mm Brakes - 57mm Piston
    Hi,
    Does anybody know the part number for the calipers from the Mk4 era that had the 57mm piston instead of the 54mm piston?
    Does the 3mm make a big difference in reality?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    It was the a4 calipers I think that had 57mm pistons. Better off going for a brembo setup.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    the larger piston will give a longer pedal....
    <tuffty/>
  1. Rear Brake caliper piston tool
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2008, 11:29
  2. Will 15" alloys to fit over 312mm brakes?
    By MikeA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2007, 23:32
  3. 312mm Brake Upgrade - How To?
    Last Post: 12th February 2007, 13:50
  4. 312mm brake conversion
    By macca in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2006, 20:03
  5. My 312mm Brake upgrade.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2005, 22:45
