My brakes are stock, DS2500's up front, stock rears. Its not been on track yet though, and i suspect they'll need upgraded eventually. For me, i want the lightest brakes that will do the job. I could go fit some massive things from an RS4 or whatever, but thats IMO completely OTT and the extra weight just works against what your trying to achieve as its all unsprung and rotating mass.
That said, i've tracked my road car, also on stock brakes with stock pads, and on stock power it was completely fine. Sure after maybe 10 hard laps they'd be starting to go off a bit and you'd want to cool them off, but given i wasnt wanting to trash the hell out my road car it worked well enough. Evidently once the power starts going up (and ability/confidence too i guess) then the brakes get a harder time of it. The track cars lighter, and has the same brakes as the road car with DS2500 pads, so i'm hopeful it'll be ok to get me started.
The other issue is it depends on the track itself. Knockhill is a fairly tight circuit and is quite short. Some much faster more open tracks you'll be braking from higher speeds etc, which will tax the brakes more.
As for bias, i dont know what your car is, but the LCR ran those brembos with the 256 rears. IF you've got 256 rears then the bias should be acceptable. If your still on the stock 236mm rears however, then you'll have moved the bias forwards, which isnt ideal, as essentially the rear wheels end up doing less than they could, and the overall braking torque to the road surface falls.
I'm not a fan of Toyo's, bar maybe the R888. Clearly they're not ditchfinders, but they're no Eagle F1 either.
