EM TuningMonster Motorsport
    Dec 2013
    115
    s3 8l bam, missing at idle
    Hi guys
    So the list of mods:
    - 3" custom downpipe/decat and 3" "catless" back exhaust system
    - 42 draft designs intake
    - 3" TIP
    - n75H ECS racing valve
    - Turbosmart Kompact DV its a full recirc valve
    - PCV delete/ catch can install
    - N249 delete
    - 600x280x76 2.5 in/out FMIC sitting in pieces ready to go on
    car has been fine(ish) up until about a week ago (about a week or 2 after I fitted the turbosmart Kompact plumb back DV, which flutters quite a lot - and n75H from ECS things have gone a little rough), always had the pressure drop between intake and dv code since buying it. But now at idle, instead of just fluctuating a bit, it feels like its skipping a beat quite consistently (fine under throttle, though the turbo seems to have become rather inconsistent but when consistent pulls really hard!) The idle misses badly enough for what sounds like knocking to occur, (checked oil levels just incase, all good here) the problem is pretty severe, it can make the whole car jolt and shudder and it almost feels as if the engine cuts out momentarily sometimes. Coilpacks are the recalled model, plugs are only about 3 months old.
    MAP has been cleaned but didn't make much of a difference. There's no spacer in the post cat lambda (never had a cel though, but possibly lambda problems?) old worn or blocked injectors maybe? bad fuel filter, fuel pump? Id have thought these would have thrown codes?
    no missfire codes either.
    one thing, when i used to unplug the EGT the fluctuating idle issues vanished, I haven't tried this again yet as I want to get clear codes.
    Unplugging the MAF makes no difference at all.
    Cleared all the codes with vcds-lite before really taking note of them (id done things like unplug the maf, egt, disconnected the batteyr etc so had a ton of codes that wouldn't give me a clear reading), will take it for a spin today and rescan to see what I get
    I do need to add, I changed the coolant temp sensor to reveal my thermostat is gone, car never gets above 70 when driving, most the time sits on 60 (climate control says about 55) when driving. If I idle it will eventually hit 90 but drop the second I move. So that's on its way, will change it on monday, could this be the cause? This has been the case for about a month though and these rough idle symptoms seem to be new.
    Another note, once or twice its felt like this before when my fuel gets really really low, fuel pump on its way out maybe?
    ideas?
    Greg-S3's Avatar
    Aug 2012
    Northampton
    331
    Have you checked the gaps on the spark plugs? I chased a misfire at idle once, turned out to be a dud plug gap. Your boost issue could be a weak waste gate? Are your breather pipes ok? Vac pipes under the manifold ok?
    Audi S3 AMK in dolphin grey, cleaner than clean!
    CMcKenzie's Avatar
    It's supposed to do that..
    Apr 2012
    East Yorkshire
    283
    Add CMcKenzie on Facebook Visit CMcKenzie's Youtube Channel Visit CMcKenzie's Instagram Channel
    Try swapping your DV and N75 for the original-tried and tested to work-parts. Clear any fault codes, I can pretty much guarantee they're the cause of your problems.
    2000 APY S3
    If you fit a split-r I will ban you from ASN
  1. Another TDI with Missing/Lumpy Idle
    By Ga1050 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2013, 23:05
  2. Replies: 13
    Last Post: 17th August 2012, 11:48
  3. 2.0T running a little sluggish and intermittent miss at idle
    By prel2000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th June 2012, 22:18
  4. Missing in idle - major issue please help
    By urban-audi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th December 2009, 17:10
  5. slight miss on idle
    By vw754 in forum Diesel forum
    Last Post: 7th April 2009, 00:42
Tags for this Thread
