Hi All,
I've recently put my car back together (1996 8l Audi 1.8l 20v). Engine rebuild. Prior to starting this project I had been told that the instrument cluster was a bit dodgy in that it intermittently worked. I've now found this out for my self and Its one of those problems that just stumps you.
I've downloaded VCDS lite. I have bought an ebay knockoff cable "KKL". on test the cable was found but always receives a "no response from controller" error.
I have tried another cable and another laptop with Registered version of Lite. same problem exactly.
I removed the instrument panel, found nothing as expected, but on re-fitment the Clocks have started to show life, including the immobilizer which temporarily prevented me from starting until I played around some more. the dials ALWAYS go dead once the engine is running. (fuel, temp, rev, odometer) but the lights remain active. Before I wasn't getting Oil pressure warning light either.
So at the moment the clocks are either loosing connectivity, (power, earth) or are at fault.
But none of this explains why I cant connect through k-line. To change the clocks I will need access to the key for immobilizer. also the fuse seems okay (#12 - 7.5a)
Can anyone point me in the right direction please. this has become tiresome.
