Volks AutosSky Insurance
    Feb 2004
    UK
    1,320
    Brake Fluid Change,amount?
    How many litres will i need? Sure it's in my data manual somewhere.
    May 2003
    Reading
    705
    Re: Brake Fluid Change,amount?
    When mine was done at the dealers a couple of weeks ago they charged for 2 litres.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    It should only take about 1 litre, but get 2.
    I used about 1.5l when I last did mine.
    Get a syringe and pull out most of the old fluid from the master cylinder before you start adding new stuff, but obviously do go too low.
    If you are using one of those one man auto bleeding kits that use the spare wheel to push fluid through, make sure you don't exceed 1bar of pressure. So deflate the tyre to about 14psi first. Using a greater presssure causes a valve in the EDL sysem to close and you won't flush that part out.
    Feb 2004
    UK
    1,320
    thanks guys.
