I posted in order of size.
All have same size pistons.
Pads increase in size
Lcr 323mm disc 28mm wide
Boxsters/996 carrera s 330mm disc 28mm wide (alfa romeo disc drilled to correct pcd)
996 turbo/c4s 334mm 32mm wid3 r32 golf disc
Are you sure about that?
I'm near certain the LCRs are 36mm / 40mm
And the 996 turbo are 36mm / 44mm
Anyone tried radial fitment Alfa 159/Brera Brembos?
Ultimately there is a reason why people go lcr or porsche route.
its easy cheap and proven. Big brakes are worth every penny!!!
Pads are cheaper than lcr for ds3000 i thought?
Also discs can now be got for under 130 a pair
Tbh i wish i got 996 turbo but got impatient waiting
Jojo that the kit your selling?
Theres no point fitting brakes that are too big.
If LCR brembos are enough, then "upgrading" to 996 turbos with massive disks only serves to increase unsprung weight in all the wrong places and in effect will make the car slower, as well as emptying your wallet further, for no actual gain.
Essentially lcr caliper. Again by the time you get mounts you will be worse off
The ECS 2 piece set up with 334mm x 32mm 'massive' discs and 996t callipers will actually work out lighter than a R32 OEM set up.
Mounts i might be able to get made up for free/beer/biscuits at work, the calipers seem to come up quite frequently at much lower prices than LCR calipers; I was just curious as a lot of the LCR kits that come up seem to have pads and discs with very little life and calipers that look like they could do with a damn good refurb. What can I realistically expect to pay for a decent LCR brembo kit?
Trying to work out if these Alfa calipers will fit on 312mm or 323mm VAG discs, but as you've pointed out I guess there are several reasons why people haven't really bothered with them. But if the cost of mounts is the main one and they will fit VAG discs then it could be a goer..
What alfa is it?
Ok. So pedal travel will increase.
Well only you can decide what to do mate. Check the pad dimensions make sure they are close.
Some alfa calipers share pad dimensions to lcr brembos. They are just thicker!
