    Feb 2014
    107
    Fuel pump help needed
    I'm replacing my fuel pump but when I took it out this was not connected. How does it clip on to the pump? I can't figure it out and can I just leave it in the tank?
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Its a bit off a ball ache that part.
    The bit clips in the gap between the pump body and that plate where the wires run down. the gap fits onto the screw you can see behind the wires.
    You have to do this process blind as it wont fit into the hole with it attached so do it a couple of times out of the tank first to see how it does it then repeat with both bits inside the tank
    make sure no hoses are kinked before reffiting the seal
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Feb 2014
    107
    ahhh makes sense. cheers. i just left it hanging in the tank for ow. will sort it when i get a chance
  1. S3 fuel pump help - wrong part?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2012, 08:25
  2. Fuel pump clip needed urgent
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2012, 18:03
  3. Ticking on 1st ignition, could be from the fuel pump??? Help
    By haytch75 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2011, 16:19
  4. 2.5 tdi poss fueling issue. help needed
    By a4-rob in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2010, 22:05
  5. Cambelt/water pump help needed
    By Fishy_bob in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2009, 21:44
