EM TuningAH Fabrications
Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By 16Klappe
Thread: Advice on S3 performance
    Jul 2014
    Hi im new to this forum, ive had my s3 a little over a month now and i love it, need more power though ha.
    Its apparently had a stage 2 REVO map but no paperwork to prove it,
    K&N panel filter,
    De-baffled boost pipe,
    De-cat
    I had it Dyno'd at Revo-tune in durham and it only put out 216.1
    Only 6bhp more than standard
    I want a front mount intercooler for it but apparently Universal kits dont give much gain and decent kits are like £800!
    I also want a full stainless but dont know what bore to get 2 1/2" or 3"
    Then could anyone recomend a good induction kit?
    Then once all of this is done a Dyno Remap?
    Any advice will be fantastic, Thanks
    May 2013
    236
    dont be sucked into expensive FMIC, i had an S3 with a forge front mount, quite an expensive kit by all accounts, put on by a previous owner, it also had a big turbo conversion done and when i removed the forge it had split the welds on the end tanks, i called forge and they said they are only good for about 330/340hp (can't remember exactly but it wasn't much) search up welly cooler on here that route isn't a huge amount and seems pretty decent, depends on the budget really
    Jul 2014
    Im confused, whats a welly cooler? lol
    May 2013
    236
    cools ya boots man
    May 2013
    236
    but seriously, its a user on here that did a fmic mod that others have copied by all accounts, do a search and all will become clear
    Jul 2014
    Ive just had a quick search and it just looks like a bigger diameter cooler, ive just found an airtec frontmount on ebay for £450, only £100 more than a universal kit
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,459
    There is a FMIC thread in the FAQs...
    AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy)
    As said, the cheaper option id the 'welly cooler' which is essentially a largish eBay/toyosport one... retaining the foglights and grilles takes a little effort but if you are not fussed about that then all good... if you want the OE look then the AH Fabs V2 is the one to go for... have a word with Alex or Lars at AH Fabrications about one... should cost you around £400 plus pipes...
    <tuffty/>
    Mar 2013
    Devon
    563
    This is a welly cooler:
    FMIC FFRONT MOUNT TURBO INTERCOOLER TYPE B 600x300x76MM 5001 | eBay
    Loads of fitting info on this particular cooler on the forum if you look for it.
    Audi S3 8L in absolute red, Stage 2 tuned & Golf MK4 GT TDI PD, bright green pearl, also Stage 2 tuned... 23mpg vs 53mpg!
    Artsa's Avatar
    Sep 2013
    Chepstow
    143
    Aug 2011
    Plymouth
    731
    Add Lavis89 on Facebook
    rather than buying a full kit it is usually cheaper to buy a core (either welly or ahfabs) then order the pipework to suit, check other peoples build threads, loads of people run FMICs
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Revo Steve-W's Avatar
    Jul 2013
    Daventry, Northampton
    204
    Add Revo Steve-W on Facebook
    It sure doesn't sound like it's running Revo then, unless set to Stock mode?
    Give your local dealer a call, they will be able to check settings for you, also if Revo they can datalog and set the car up properly on the road - Dealer Locator | REVO, Race Bred Adrenaline
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,014
    Visit 16Klappe's Instagram Channel
    I would be looking into why you have such **** power before looking at an FMIC.
    Lavis89 and Revo Steve-W like this.
    I quite often say I'm going to do things.
    Then never do them.
  1. after some advice performence upgrade
    By jonno123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2012, 21:03
  2. Performance Tuning Advice
    By djx11b in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2011, 01:11
  3. Performance mods advice needed
    By JeffY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2009, 01:38
  4. Performance Upgrade Advice?
    By Blowfish in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2009, 12:37
  5. My S4, Westec Performance and advice. Monster BHP or not?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2006, 10:05
