Volks AutosBadger5
Results 1 to 8 of 8
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,112
    Vibration under braking
    Under hard braking I'm getting a lot of vibration.
    Could that be a sign of needing new brake pads and/or disks?
    The pads still look like they have a bit of life left in them (maybe a few thousand miles).
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Re: Vibration under braking
    I assume you've checked your wheels are torqued up correctly. Balanced etc.
    Also your disks could be warped.
    AL
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,112
    [ QUOTE ]
    AL
    [/ QUOTE ]
    The torque of the wheel bolts was the first thing I checked - they all seem fine.
    I have Brembo brakes... are they warpable with spirited A and B road driving (no track days).
    AL_B's Avatar
    1,564
    I thought you would have checked that, but had to ask, sorry.
    Brembo brakes, dunno. If its the GT Junior kit, they can warp...but that was a guy who did a lot of track days...SITAS3 (Simon Taylor)...he's still around sometimes.
    AL
    nervus's Avatar
    Apr 2004
    1,159
    Jojo warped his Brembo discs too, IIRC.
    If they are warped you should feel the vibration through the steering wheel as the steering will be pulled with the warped disc as you apply brake pressure.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    [ QUOTE ]
    [/ QUOTE ]
    Yup, I warped a pair of Brembo disks, S3's have crap brake cooling, and they weigh a lot, so the brakes get pretty hot with track work. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    All you have to do is bin those silly brake shield things that are on the inside. I binned mine within a week of getting the car!
    With them gone, you get better cooling...there's nothing wrong with the S3 's cooling once you bin them.
    I never ever got my brakes - standard or Brembos - too hot...
    Bin the shields!!
    Apr 2006
    london
    9
    Yep deffinayely sounds like warped discs. Have the S3 setup on my Golf and had exactly the same symptoms. changed discs and all is fine. I binned the shields too and deffinately get better brake cooling. and less brake fade.
