Chris NottMonster Motorsport
Results 1 to 18 of 18
    Mar 2006
    Leicester
    95
    210 / 225 Base Engine Differences
    Aside from a map difference, was there any changes made by Audi to the base engine when they up'ed the bhp to 225? Cheers
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: 210 / 225 Base Engine Differences
    As far as I know it goes something like this:
    Early APY engine - large port, no vvt, larger gudeon pins (20mm).
    later AMK engine - small port, no vvt, small gudeon pin (19mm) extra emissions stuff x2 lambda probes etc
    Latest BAM - As AMK but with vvt.
    Ryan will probably be able to give you anything I've missed.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    VVT being varible valve timing ?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    I dont think the APY was a large port... Could be wrong though.
    Rich
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Good point Rich. I think you are right on that one.
    Triple_A's Avatar
    May 2004
    Turku, Finland
    99
    I think that APY has also VVT but it is mechanical and BAM has electrical VVT.
    Mar 2006
    Leicester
    95
    Thanks for the input so far... What does each of these things give the engine?
    Assume VVT is variable valve timing and is all about power? Similar to Honda's VTEC? Giving an increased rev limit?
    Why reduce the size of the gudgeon pin? More free-reving? Piston head change also?
    Port? Improved gas flow? Inc power?
    Trying to understand the changes that went on and the reasons for them. Hope you don't mind all the questions! Jon
    Feb 2004
    UK
    1,320
    apy ,no vvt, i have a head in front of me, amk,bam does have vvt.
    All are smallport.
    vvt is just for emissions.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    All are smallport.
    [/ QUOTE ]
    Bingo Ryan...
    VVT only at idle...adjusting the intercam timing...nothing like VTEC.
    imported_hookie
    All remap to as near as damn it tuned so go figure! [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Feb 2004
    UK
    1,320
    yep,people have tried activating the vvt ,does nothing.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Thanks for the help guys!
    I'd also like to know whay the gudeon pin sized was reduced.
    Jodi's Avatar
    Starsky
    Mar 2004
    Herts
    45
    So if a BAM engine was fitted to a car with an APY engine's ECU, would it work? Basically, is there really no difference?
    Feb 2004
    UK
    1,320
    no. You would have to change the head.vvt module on bam
    Jodi's Avatar
    Starsky
    Mar 2004
    Herts
    45
    Surely the BAM engine would still work with an APY ecu, but without the vvt working?
    Feb 2004
    UK
    1,320
    Bam is me 7.5 and dual lambada and apy is single .It might run but how well ??
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    i remember hearing on a course once that the only difference with the vvt engines was the mapping, but have never been bothered to check it out!!!
    Feb 2004
    UK
    1,320
    The apy's are definetly not vvt.
