JMB RetrofitsEM Tuning
Results 1 to 23 of 23
Like Tree3Likes
  • 1 Post By Scullies
  • 2 Post By badger5
Thread: Audis AMK s3 poor rear suspension SAFETY design, do you have the same issue??
    Jun 2014
    13
    rear suspesion.jpgstockbolt.jpg Hi folks I am new here, When I bought my first audi s3,the rear control arm which hold by a M12X10cm bolt to the strut with out using another lock nuts(it was too short anyway, I had to buy M12X12cm so I can put a lock nuts on to secure). What happened was, I tried to change the rear spring and I removed the bolt with out releasing excess tension from shocks, as a result I threaded the thread-only slight( my fault but...... But I did not know. I kept driving next day, on the same night the bolt came off, lucky the weight of the car holds the rear spring the rear shocks is actually came off only the top part being hold until I stopped the car and saw it.. In mid night I walked home and get my other car and get a jack ready to fix my car.-simply put a longer bolt in with a lock nut.
    In my opinion coming from Hondas. I think this is a FAULTY design of Audi. They should have had a longer bolt with a secured nuts just like others. What do you think?
    Dec 2003
    n.ireland
    202
    Dude you damaged it , nothing to do with being a bad design ,
    Jun 2014
    13
    Quote Originally Posted by curtis11 View Post
    still all the previous car i have had a bolt to the end of bolt except Audi..hummm save money....
    May 2013
    287
    yeah that will be it, audi sell a car for £25k and save money but not putting 2x lock nuts on a pair of bolts in order to save masses of money and compromise the safety of the drivers
    and that bolt doesnt actually bear any weight off the car, its there to tie the arb link and shock, the shock doesnt hold the weight of the car
    Lewis583's Avatar
    Mar 2010
    870
    They don't need a Nylock nut. If a bolt is torqued to the correct spec then it won't come undone.
    Simple fact is, if you didn't knacker the thread then it wouldn't have failed.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I think..... you have done something awesome by selling your Honda
    Jun 2014
    13
    Quote Originally Posted by Scullies View Post
    you are right, i noticed Audi has a much stronge rbody and ride quality. Some how the rear bolt, if not done properly-like me, yes it would fail. At least now the car is secured, that the bolt does not slip out like before. I was lucky. One thing I also noticed Honda had a better/stronger sump nut/thread, Audi is full of Aluminium where as Hoda they mad a steel thread, so it does not overstripped liek most VW /Audi owners-again, correct torque to tigthen the nut is important.
    May 2013
    287
    sorry thats rubbish, you damaged the thread and now complain its a safety feature, I've owned many of these haldex cars (4motions/R32/S3's) and none have failed, i have broken even more and yet again no sign of anything failing, i think you are just a little anxious about this supposed factory failing because you didn't know how to do the job properly in the first place. Really isn't an Audi fault.
    Mar 2008
    62
    You've ****ed it up and looking for someone else to blame!
    May 2013
    287
    i think he should write to audi/volkswagen and demand a safety recall for all haldex cars
    Dear Mr Audi
    Please put longer bolts and nyloc nuts on the bottom of the shocks because its not as good as my old honda.
    RIP S3dave
    May 2004
    nr Glos
    7,162
    Quote Originally Posted by oldcar View Post
    go back to honda's seeing you luv them so much
    vtec - Yo!
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Jun 2014
    13
    haaa funny ****...no I said Mr.AUDi please spent an extra 20 cents for a longer bolt so people liek me wont complain. haaaaaaa
    Any way, I just found this strange? How come all Mercedes and BMWs had an extra nut. Must be a reason...I think the new S3 had nut too? correct me if I am wrong.
    May 2013
    287
    i dont really think audi wants people like you. 6 posts and you have made a great 1st impression
    Jun 2014
    13
    vtec - Yo!
    When I bought this s3, the sump nut was striiped by the previous owner, he had use a slight bigger M14, when I did an oil change, it was hard not to stop a slight leak. I ended up putting a heli coil in myself and put an after market bolt with an O ring around it. These small things Audi should have done a better job, since we paying for a big $; where as for Mercedes E280, they had a steel thread and that shows Mercedez is a better design-in some ways.
    May 2013
    287
    what a tit, so a previous owner stripped a thread (sounds as if he is as good with spanners as you are...) and thats Audis fault too.
    You sir are a tool
    the more i think about this i believe you have deliberately come on here to spam the forum with crap
    Jun 2014
    13
    Quote Originally Posted by jasongtr View Post
    You sir are a tool
    PLEASE JAson, no spam here, it was just a shocking experience, that I NEVER NEVER had a car with sump thread made out of aluminium as I am awared now all japanese cars had steel thread so as Mercedez. I own few this is what I have experienced, nothing to spam about. The car now does not leak, but I know now, with VW and AUDI its slight different.
    May 2013
    287
    what is shocking is there have been two points to moan about with your car, both have been caused by incompetent people who quite possibly should not be allowed to service their own cars. Nothing to do with the manufacturer just monkeys with tools
    Mar 2013
    Chelmsford , Essex .
    235
    Perhaps Douglas bikes use a alloy sump plug thread too ?
    1999 Silver 8L A3 1.8t sport (AGU) currently undergoing rolling modification
    pipercross panel , bosch super 4's , poly bushed front end , yellow dogbone , self refurbed 16" speedlines , ambient lighting.............TBC
    http://www.audi-sport.net/vb/a3-s3-f...ts-thread.html
    RIP S3dave
    May 2004
    nr Glos
    7,162
    ok.. you're wrong
    simples
    basil brush and newbster like this.
    bill@badger5.co.uk
    Jun 2014
    13
    ok.. you're wrong
    simples
    funny **** indeed, by the way that monkey is clever, because he fixed the bike....haaaaaaaaaaaaaa
    RIP S3dave
    May 2004
    nr Glos
    7,162
    you think?
    lol
    bill@badger5.co.uk
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    oh my
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    Point made.
    Locked!
  1. audi a3 8p /golf mk5 rear suspension beam/axle/cradle
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2012, 07:05
  2. Replies: 13
    Last Post: 26th September 2011, 09:57
  3. Which other models have the same rear calipers?
    By diggerbucket in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2010, 13:22
  4. Rear Park Sensor Question if you have ETKA pls!
    By Sarah's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2010, 03:19
  5. A3 rear suspension knocking - Audi recall?
    By Karcsi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2005, 17:53
