Sky InsuranceVolks Autos
Results 1 to 10 of 10
    Gaz-M's Avatar
    Jun 2014
    95
    Going stage 2- Looking for downpipe & decat. Which one?
    My mate has a 2001 S3 and is after a 3" downpipe and de-cat so he can go stage 2. He isnt keen on paying £350 kind of money, i see theres talk of a £86 one that needs flange modified or cut or something, whats the deal with that?
    He has a milltek catback, intake, TIP and i think a stage 1 map already, how much better will it be with downpipe/ decat and stage 2 software?
    Aug 2011
    Plymouth
    745
    Add Lavis89 on Facebook
    im guessing the £86 one is the k03 downpipe, would need to modify it to fit a k04, not sure what is involved tbh. can't imagine it being too hard of a job if you can tig weld and have a chopsaw
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Gaz-M's Avatar
    Jun 2014
    95
    Hmm feck that!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    86 quid one will be for a K03 (fwd A3, Glof etc)... S3 ones are available from Pipewerx or Relentless...
    Better quality Pipewerx one is more expensive..
    Audi TT S3 3" Exhaust Down Pipe & De Cat Bypass | eBay
    ...but a lot of S3 owners here use the relentless one which can be variable quality and fitment wise but cheaper
    Downpipe Audi S3 TT Seat Leon 1.8T 3" Decat De Cat exhaust down pipe UK STOCK | eBay
    Just make sure you use an OE gasket for the turbo to DP as the perforated ones supplied are next to useless
    <tuffty/>
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    <tuffty/>
    Take Tufftys advice, i fitted my relentless with the gasket supplied and it was blowing withing 48 hours. Get a oem one from TPS for £8 and save yourself a world of pain
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
    Gaz-M's Avatar
    Jun 2014
    95
    Thanks chaps, im going to order him one of those relentless ones and a Audi gasket as per your advice. Much appreciated.
    Will he notice a big difference between stage 1 and fitting this and stage 2 mapping?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Stage 2 typically gives more midrange power/torque with the right setup... these types of mods are all about keeping the engine happy temperature wise so the ECU doesn't intervene as much when cylinder temps/EGTs rise.
    <tuffty/>
    Gaz-M's Avatar
    Jun 2014
    95
    Cheers, downpipe on its way thanks for advice. Will update when fitted and mapped!
    Jun 2014
    19
    has he not got fmic? + 1 for blow exhaust gasket after market are rubbish i just replaced mine for one from audi dealer was a ass hole of a job when you have 3" down pipe and relentless exhaust mani
    Gaz-M's Avatar
    Jun 2014
    95
    Yeh it has a Forge front mount, Milltek decat and an intake kit.
  1. looking for audi s3 decat asap ;)
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2011, 09:25
  2. Removing my vinyl wrap for another colour, but which one?!!!!
    By cfoster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2011, 03:36
  3. Anyone looking for a S3 avoid this one.
    By Soupie69uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2008, 09:39
  4. The A3 might be going for a Diesel... but which one?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2006, 19:51
  5. APR chip or Revo remap for A4 1.9tdi? Which one?
    By oneniner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2004, 20:56
