Sky InsuranceAH Fabrications
    Aug 2011
    Plymouth
    745
    Add Lavis89 on Facebook
    A3 Fmic hot side pipe route question.
    I'm almost ready to refit the bumper, only question I have at the moment is where have people run the pipe coming off the hot side of the cooler. Mine is currently like this
    Can I get away with this? It looks a bit close to the ground. Or do I need to take a jigsaw to the plastic trim by the horn?
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Mar 2013
    32
    Holesaw through the engine cover there, relocate the horn slightly then up you come beyond the battery IIRC
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    Yep, I also cut away at the cover over the gearbox. Forcefully pushed and bent the horn back a bit
    <Jay A3 build thread>
    241bhp K03s - R Tech
    Aug 2011
    Plymouth
    745
    all done now, just got to flip the cooler because the inlets are a bit too low then put the lower valance back on and the job is done(ish) going to play around with the pipeing a bit but got it back on the road for now. Cheers guys
  1. ToyoSport FMIC engine bay pipes. OEM look. pics inside
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2012, 19:43
  2. Pipe routing for a custom fmic. 1.8t ary.
    By benclarke in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2012, 08:01
  3. S3 Rear wash pipe routing- help needed
    By sportquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2010, 11:14
  4. S3: (FMIC piping) Why 2" on hot side and 2.5" on cold side
    By Dennis Moeller in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2009, 01:53
  5. evomaster300 or anyone else- Amp power cable routing question
    By TonyT in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st May 2007, 12:52
