A3 Fmic hot side pipe route question.
Lavis89
Plymouth
Website
www.facebook.com
I'm almost ready to refit the bumper, only question I have at the moment is where have people run the pipe coming off the hot side of the cooler. Mine is currently like this
Can I get away with this? It looks a bit close to the ground. Or do I need to take a jigsaw to the plastic trim by the horn?
Holesaw through the engine cover there, relocate the horn slightly then up you come beyond the battery IIRC
Yep, I also cut away at the cover over the gearbox. Forcefully pushed and bent the horn back a bit
all done now, just got to flip the cooler because the inlets are a bit too low then put the lower valance back on and the job is done(ish) going to play around with the pipeing a bit but got it back on the road for now. Cheers guys
415
778
776
737
