Badger5AH Fabrications
Results 1 to 11 of 11
    Apr 2013
    Dumfries and Galloway
    45
    oil in drivers side footwell
    Hi guys, bit of a weird problem with my 2001 1.8t, whenever i lift the drivers matt, there seems to be an oily substance on the carpet, sort of like baby oil
    can anyone think what it could be?
    Dave
    Greg-S3's Avatar
    Aug 2012
    Northampton
    328
    Could it be a previous spillage? Perhaps the recent heat is bringing it back up?
    Audi S3 AMK in dolphin grey, cleaner than clean!
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    clutch or brake fluid?? coolant from a leaking heater matrix?
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    129
    +1 Had similar issues few years back on 80 coupe, was coolant loss from heater matrix. could be expensive sorry ..:sadwalk:
    B5 Avant 2.5 tdi 2000 X reg , Jaspis green, carbon vinyl roof and door pillars, remapped, fmic, 18" bbs lm rims, custom exhaust, coilovers, RS4 front bumper and grill, tints allround, pillar mounted boost/oil pressure guages, solid flywheel conversion.....
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Heater matrix is passenger side I think
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Matrix is passenger side... its most likely brake fluid from the clutch master cylinder
    <tuffty/>
    Apr 2013
    45
    hmmm doesn,t smell like brake fluid. I dunno, last thing i want to do is rip the carpet up. Also the rear wiper doesn,t work, can the hose split under the carpet?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    Look up at the servo by the pedal box fir leakage
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Quote Originally Posted by bigdavevw View Post
    also passenger side
    Alex S3 AMK
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    hmmm strange
    have you lent the car to your missus ?
    epox's Avatar
    Oct 2012
    Glasgow
    592
    Check the fluid levels first, have you had to top up any fluids?
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
  1. Water Leak in Driver Side Footwell
    By bug in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2012, 10:47
  2. Drivers Side Footwells Swimming Pool - but not the plenum plugs
    By miniredcooper in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2012, 20:19
  3. Replies: 10
    Last Post: 27th October 2010, 20:44
  4. Water in the driver side footwell
    By Kostas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2009, 18:34
  5. oil on driver side of engine bay on 1.9TDi (130)
    By lgatland in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2006, 22:02
