It's pretty tight - I think it's easiest to unplug the connector (it pulls downwards out of the back of the cluster), then (IIRC) there is a plastic clip on each side of the cluster.
You should be able to ease the "bulb board" backwards out of the reflective housing, bit it is tight, and I think that one bulb always used to rub a little when I used to take mine out.
