plastic one is fine so long as it's changed every time the cam-belt is changed... If it's not the impeller gets brittle and basically ends up falling apart!
The other month we had a Leon TDI in with cambelt failure resulting in a seriously mashed piston!... Engine was removed, rebuilt and put back in the car. When we rebuilt the engine we used a metal FAI water pump.
After literally 9 miles the car was seriously over-heating. We scratched out heads, did some tests and everything pointed towards water pump. Surely this is not possible after only 9 miles!? Either way, the pump had to come out. As soon as I removed the pump the impeller literally fell off the shaft!!!!!
A slightly unrelated and long winded story but if anything another reason NOT to go for a metal pump!..
