Sky InsuranceJMB Retrofits
Results 1 to 18 of 18
    Feb 2014
    17
    The dreaded P0172 code Bank 1 too rich
    Hello guys,
    Got the pain in the arse P0172 code and tbh it's driving me mad...
    Car is an a3 2001 1.8T AUM with 63,000 miles and is standard atm.
    Car has thrown a bank 1 too rich code at me.
    There are no driving problems with the car that I know of , it just idles badly.
    The car seems to hate a cold engine on start up and idles about 1100-1200rpm for about 30 seconds and then goes back to the normal idle at about 700rpm.
    Her idle then fluctuates about 100rpm constantly.
    I have attached a couple of videos (I hope it's worked)
    Things I have done - New Bosch mass air flow sensor , new oem diverter valve , checked for vac leaks and non present that me or the mechanic can see , Forte specialist fuel injector cleaner , new engine temp sensor .
    Im no mechanic but I'm leaning towards a new lambda sensor or fuel pressure regulator.
    Just wondering if anyone else had any other ideas at all ?
    Btw I don't listen to Beyoncé , in the video it just had to come on the radio at the same time of recording...
    http://m.youtube.com/watch?v=hanwB1aZ3LI
    http://m.youtube.com/watch?v=BSAVf90zPPk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    Feb 2014
    17
    Cheers tuffty , will check this tomorrow .
    The idle definitely sounds more like a fuel delivery problem.
    Don't Lamda sensors usually throw there own codes ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    16556/P0172/000370 - Ross-Tech Wiki
    16556/P0172 - System Too Rich, Bank 1
    Possible Symptoms
    Irregular behaviour
    Possible Causes
    Fuel system
    Excessive fuel pressure
    Leaking or contaminated fuel injectors
    Leaking fuel pressure regulator
    Low fuel pressure or running out of fuel
    Vapor recovery system
    Air leaks after the MAF
    Vacuum leaks
    Improper seated engine oil dipstick
    Stuck EGR valve
    Oil overfill
    Cam timing
    Cylinder compression
    Exhaust leaks before or near HO2Ss.
    <tuffty/>
    Feb 2014
    17
    Possible Symptoms
    Irregular behaviour
    Possible Causes
    Fuel system
    Vacuum leaks
    Stuck EGR valve
    Oil overfill
    Cam timing
    <tuffty/>
    Fuel pressure regulator was clean as a whistle , got some live data from my cheap d900 scanner which I don't know if these mean anything to you guys ?
    Calc load--1.56%
    Coolant temp--98 degrees
    Stft b1 was ranging between 14-18%
    Ltft b1--3.12%
    Spark adv--18.5btcd
    I.A.T--53.0C
    M.A.F--1.96
    TPS--2.35
    air status--OFF
    O2SL--11 12
    O2S 12--0.635V
    SHRTFT12--99.21%
    OBDSUP--EOBD
    this data was taken at idle after a 25mile drive.
    Thanks for the help.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    Air leak by the looks of that... short term trims are high but long term trims are just over 3%
    I'd be checking the pipes under the inlet manifold... smoke test will reveal any leaks if you can get one done... obvious signs of leaks is wet oil residue... engines get dirty over time... if there is oil on the outside the its leaked out of hose or seal...
    <tuffty/>
    Feb 2014
    17
    Been trying to find someone with a smoke test for months without driving a good few hours away , smoke test is the only way I think as I've looked for hours for leaks . I think the car may have had a map by a mobile mechanic (maybe done a rubbish job) would that effect it ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    I thought you said your car was standard?...
    I bad map on a wideband car doesn't normally create these symptoms and as I said your short term trims suggests a split pipe as does the bad idle...
    <tuffty/>
    Feb 2014
    17
    <tuffty/>
    I meant the car was standard to my knowledge , it might not of been mapped but there was a sticker on my engine bay from a mobile mechanic who also does 'tuning maps'. He might of even just changed a battery or something I don't know.
    Anyone you know do smoke tests ?
    The only people i know are rtech but that's a 4 hour round trip for me.
    I'm in the surrey/hampshire/London area.
    I do appreciate your help btw.
    Aug 2011
    Plymouth
    728
    Add Lavis89 on Facebook
    Pcv split caused this on my car, get it smoke tested before you keep throwing new parts in
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Feb 2014
    17
    Quote Originally Posted by Lavis89 View Post
    So last night I got the car smoke tested and there are no leaks apart from a bit of smoke coming from the bottom of the dipstick which I was told to replace ASAP. Part comes Monday but would that cause my bank 1 fuel trim to be at that level ?
    Any other suggestions at all ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,450
    Have you checked the FPR/fuel rail as per the link I posted in post #2?
    <tuffty/>
    Feb 2014
    17
    <tuffty/>
    Yes checked that and was clean as a whistle , the vacuum hose to the fpr was a bit soft and caving in so it's been changed.
    Feb 2014
    17
    And now it seems to be misfiring, any ideas ?
    Feb 2014
    17
    <tuffty/>
    So my stft are now bouncing between 21-26 so I guess my misfire is because it's just to high now to be properly burned or something on the lines ?
    So my list of work has been -
    new Bosch maf sensor
    New oem dv
    new coolant temp sensor
    smoke tested
    fpr regualtor seems to be clean and working
    No leaks in the exhaust
    so out of the list in post 4 there is only fuel injectors , vapour recovery system (would a clogged up PVC valve cause this ?) and cam timing
    all help is appreciated !
    RIP S3dave
    May 2004
    nr Glos
    7,135
    +21 to -26?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Feb 2014
    17
    +21 to -26?
    I believe +21 to +26 it's just keeps jumping up and down. It's always running rich.
    RIP S3dave
    May 2004
    nr Glos
    7,135
    its Adding fuel if its +
    so its running Lean and trying to add fuel to achieve target lambda
    what is 031 actually sitting at whilst 001 is +21-26%
    bill@badger5.co.uk
  1. Fuel Trim; Bank 1: System Too Rich
    By johnone in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2014, 01:02
  2. VCDS codes. Running too rich
    By autolatry in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2013, 00:00
  3. 17545 - Fuel Trim: Bank 1: System too Rich
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2011, 16:32
  4. 2006 S4 Error codes. fuel trim, system too rich
    By gez in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th November 2010, 11:04
  5. Code 17535 (P1127-35-10) System Too Rich - Bank 1
    By MikeA3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2009, 10:46
