JMB RetrofitsEM Tuning
    May 2014
    10
    Clutch problem, advice please :(
    So today I was traveling along at 30, then I go to change gear and the clutch pedal sticks to the floor, I my car out of gear, pull over, have a look under the car and it's basicly leaked out all the brake fluid and clutch fluid :/ this wasn't a gradual thing, happened all of a sudden. Has anyone had any experiences like this on their s3? I've got a 2001 s3,
    105k on the clock. Any advice on how
    i should approach this?
    thanks guys.
    May 2014
    10
    Maybe worth mentioning that my clutch pedal has been a little squeeky the last month or so, never really thought anything of it, thought it was more of a lubrication issue
    Jun 2014
    48
    Slave cylinder, seems to be the most common cause.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    If the fluid is coming from the gearbox then its the slave cylinder... if the fluid appears to around the subframe then its most likely the master cylinder... both are common problems...
    <tuffty/>
    May 2014
    10
    Thanks guys, I'm thinking its the slave as it looks like its pissing out the gearbox . I'll be towing her to my trusted mechanic tomorrow, is it worthwhile changing the flywheel while hes in there?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    You would best evaluate the state of the flywheel when the box is off... its a dual mass flywheel and they are not cheap... typically LuK replacement is around the 300 quid mark depending where you buy it from and an OE one from TPS is substantially more expensive (but is also an OE branded LuK item)...
    Currently on ECP a clutch kit including slave is listed at £185 and a DMF is either £323 or £455 depending on the VIN number... that of course will be plus labour which for the most part is a good 6-8 hours
    Make sure you use new flywheel bolts as they are one use and I'd use new clutch plate bolts too as they are not expensive...
    <tuffty/>
  1. Strange temp problem advice please
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2011, 23:02
  2. afn tdi clutch gone... advice please
    By fARQUARE in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2011, 10:23
  3. Door lock problem, advice please?
    By Trigger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2010, 14:50
  4. S3 clutch slipping !! Advice please...
    By CJ3BLUE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2009, 16:39
  5. Clutch/Gearbox Advice Please
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th October 2009, 14:52
