Volks AutosSky Insurance
Results 1 to 9 of 9
Thread: Slow wipers
    chuffer's Avatar
    Jul 2003
    Berkshire
    70
    Slow wipers
    I got very slow wipers [img]/ubbthreads/images/graemlins/confused.gif[/img]
    do I need a new motor or is there anything else it could be?
    James
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Slow wipers
    You're spindles have rusted. The rubber o ring can allow water in.
    Take the mech out and then pull the spindles out.
    Then lightly sand the rust off and reassemble with copper slip.
    They will good as new then.
    chuffer's Avatar
    Jul 2003
    Berkshire
    70
    Re: Slow wipers
    Will give it a try at the weekend. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    typ8l's Avatar
    Jul 2003
    Scotland
    14
    Re: Slow wipers
    If they're slow and juddery, could be that your wiper linkage has seized up. Happened to mine at about 80k miles.
    imported_veccyj
    Re: Slow wipers
    Yep, same thing with mine on an 'r' plate, strip down the linkage time!!!
    imported_Tariq
    Re: Slow wipers
    it might possible be a loose relay. Do your blowers stop working as well?
    imported_Nigma
    Re: Slow wipers
    Had this problem at the weekend.... Turned out to be the linkage at one end that was siezed.
    I couldn't work out how to remove the spindle though. Took the e-clip and tried hammering it out but didnt come out.
    Any thoughts?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Slow wipers
    Get yourself a cheap two or three jaw puller from halfords.
    imported_Nigma
    Re: Slow wipers
    Think i screwed up....
    Removed the linkage from the motor, without noteing the crank and linkage position. Now the wipers are are in the wrong position. Any thoughts on how i can correct this (other than the long process of trial and error).
    Thanks Anand
