Unscrew and remove the load anchors,
Remove the rear trim that runs along the opening where the lock is, 4 or 5 torx screws
Then theirs a little screw to remove inside the side panel up towards the light, then just pull it out from the bottom, takes a bit of a yank as the clips are fairly strong, you don't need to remove the whole thing just enough to get at the bottom nuts of the amp and then it will come out the gap.
