Badger5Chris Nott
    Apr 2014
    14
    Removing inner boot trim
    Hi all,
    Need to do abit of soldering on my bose amp.. but i cant figure out how the inner boot plastics come out!
    any help will be apreciated!
    A3 TQS
    Jul 2013
    Devon
    163
    Unscrew and remove the load anchors,
    Remove the rear trim that runs along the opening where the lock is, 4 or 5 torx screws
    Then theirs a little screw to remove inside the side panel up towards the light, then just pull it out from the bottom, takes a bit of a yank as the clips are fairly strong, you don't need to remove the whole thing just enough to get at the bottom nuts of the amp and then it will come out the gap.
    Heres a pic I took of the otherside
    Apr 2014
    14
    Perfect mate cheers!
  1. How to remove A3 boot trim - with photos
    By Fleagle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2013, 22:36
  2. Inner boot lid trim ??
    By Essflee in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2010, 13:25
  3. Removing boot trim
    By waring192 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2010, 20:36
  4. b6 Avant boot trim piece removal - access to wiper
    By Jimmeh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2010, 00:12
  5. Boot trim/sub removal
    By AndyMac in forum In-Car Entertainment
    Last Post: 8th February 2006, 12:55
