AGU K03s + injectors
darnich
North Greece
I plan to upgrade to a K03s turbo and just found an interesting deal
what I don't know for sure is if I can use the injectors
their part no is
Bosch: 0 280 156 061 or
VAG: 06A 906 031 BA and are of the EV6 type
as far as I know the AGU engine uses the 06A 906 031 EV6 type injectors
can anyone help?
Thank you
Kostas
Those injectors are for the later 150bhp/180bhp DBW engines. AUM/AUQ etc.
They are slightly longer than your current AGU injectors. They are not a direct fit. You need a spacers for the fuel rail to fit them. But you don't need these items for your plans.
I am running my K03s with standard injectors. Only difference is I use a 4bar fuel pressure regulator to up the flow for top end. Works fine.
If the injectors are part of a kit, you could perhaps buy them and then sell them on again?
Ok thanks!
I will probably go for a 4bar FPR instead of the injectors
I know that I also need the TIP (turbo inlet pipe) from a newer model one with a K03s
does anyone know the the OEM part number for this item?
Finally I went for the injectors as well.
The kit is off a car with only 3000 miles on it and it is only 5 months old.
I got the whole lot for £250.
However I need a TIP (turbo inlet pipe) from a model with a K03s
does anyone know the the OEM part number for this item ?
I think it is much cheaper than a silicon one....
Can somebody help me?
Thank you
be good idea to get turbo checked before you put it on by a specialist, i bought a pair of k04's of ebay a while ago told they had done 15000 miles, thought i'd get them checked anyway as its a pig of a job, turned out they had the wear of 80000miles lol, needless to say i was glad i spent £40 for them apart and £200 each for recon i got them at a low price anyway
good luck
I plan to do so....
good point!
Anyone with a part number?
Does the AGU samco TIP fit on the K03s?
The Samco TIP is a perfect fit onto the K03s inlet. This is what I have at the mo.
I will try to get a part number for the OE metal item for you. The catalogue is a bit vague as to which is the correct part. I've got one in my garage so I'll take a look later if nobody else posts.
I am afraid that the Samco TIP is going to cost as much as turbine itself....
once again thanks
I'm having trouble finding the part number for you. I took a look at my old inlet pipe for the smaller K03. The lower metal part has a number that couldn't be found in ETKA which I thought was a bit weird.
I did find a number but I think its for both the rubber and metal sections together. This is for the K03s and is 06A 133 354D. It £67 + vat over here. Not sure how much it would be for you.
I rekon you should call you local dealer to see if they can get the number for just the metal part as it should be alot cheaper.
2K
717
7K
