[ QUOTE ]
Like I said, there are those that aren't too keen on the HPP. I agree with Ess_Three's comments, but disagree at the same time.
[/ QUOTE ]
Don't get me wrong...it's a decent product, that works...and does what it should.
I just don'r think it's the answer to an S3s crap chassis...it masks the main problems, and while it doeal allow you to drive harder, it moves the chassis to the limit of it's envelope of competence...so when it goes wrong, you crash.
For me, a totally benign, properly sorted chassis allows more chucking about without the fear of a bite back...
..and you can get that on a standard Haldex controller.
[ QUOTE ]
The HPP will help with the S3's chassis issues and make it a much better drive. Sorting out the chassis issues will make it a much better drive. Either way it's better!
[/ QUOTE ]
I agree that it adds confidence to the car...and ultimately makes the car faster point to point...but I don't agree that it does it in the most controllable way...or the way that is the best from a keen driver's point of view.
[ QUOTE ]
To sort out the alignment and handling, you need front and rear ARBs (£400+VAT), adjustable rear tie-arms (£250+VAT), and a digital re-alignment (£60). I'd also recommend powerflex bushes and decent tyres. If you want to get really anal, you should also think about the unsprung weight - lighter wheels and brakes.
[/ QUOTE ]
I never bothered with bushes...but to save changing them as the S3 wears them out (which mine did) they are a good idea.
Wheels are very important...in both size and weight.
Not too wide (the S3 is overtyred in my view anyway)...and as light as you can.
Brakes...another subject completely...bling, or performance?
[ QUOTE ]
Also, if you've had a remap and are suffering from torque steer, the HPP gets rid of that too. You get four wheel drive more often, under more circumstances, and in my book that's always better than 2wd. But that's how I drive and how I like the car to feel.
[/ QUOTE ]
Do you get torque steer?
Even running 1.85 bar boost and 320+ lb-ft I was getting no torque steer at all...
Your set up must be off...
[ QUOTE ]
I think the ultimate goal should be sort out the overall set-up, but there's no reason why you shouldn't take advantage of what the car can do with the errors accounted for electronically. If you want an EVO killer, then don't forget the alphabet of acronyms they use to get from A to B.
[/ QUOTE ]
True...but you get an artificial feel to the drive then...I much prefer an organic feel...and although the numb S3 chassis isn't the best place to start...it can be done...with pretty good results.
Probably why both myself and David R wish we'd never sold 'my' old S3.
[ QUOTE ]
Personally, I like the idea of a well sorted car AND the option of more 4x4 fun!
[/ QUOTE ]
Maybe that's the difference...I don't care how many wheels are being driven...as long as it goes where I want, at the speed I want, excites, challenges and is neutral when I ****-up...it'll do for me.
