Monster MotorsportEM Tuning
Thread: door trims
    Jul 2003
    herts
    door trims
    HI, need to fit some new door trims to my a3, the trims that go round the door pulls and the electric window / mirror switches. To do this the whole door lining needs to be removed. Any one know how to do this without making a complete mess.
    Jun 2003
    World of my own
    9,813
    Re: door trims
    There's 2 screws at the top of the trim, one at each end of the door. Remove these. Then remove the main 2 screws which are hidden behind the plastic trim behind the door pull. This trim sort of slides downwards. Lift the door panel vertically upwards & out. It will still be connected to the door via lecky window cables, and door speaker cables. These can be unclipped if you need to work on the panel.
    Good Luck, Andy
    Jul 2003
    herts
    Re: door trims
    thanks mate, ill have a go tomorrow
