EM TuningBadger5
Thread: Lost 4wd
    Oct 2012
    birmingham
    245
    Question Lost 4wd
    Since replacing the pump on the diff due to making a noise I've lost 4wd the car is a 1999 s3 with a digital clock I've checked all the connections on the diff
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    First thing to do is scan your car with VAG-COM, is the new pump new or secondhand? and do you know if its a good one? (I.E not duff) check the Haldex fuse, earth strap if it has one (My 1999 APY S3 does not) also try good squirt of WD40 in the multiplug on the haldex. Have you changed the haldex oil and filter recently? If not, then do it.
    Keep us posted
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
  1. Lost keys
    By Wilo in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th April 2003, 17:06
  2. Who wants 50/50 4wd? take a look!
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2003, 08:32
  3. Different Types of 4wd explained
    By AL_B in forum General Technical / How To
    Last Post: 17th January 2003, 16:15
  4. Has all the old Technical Info been lost ?
    By Justin in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2003, 13:53
  5. A3 4WD Conversion!!
    By Moresauce in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2003, 15:02
