Monster MotorsportVolks Autos
Results 1 to 18 of 18
    Jul 2003
    Essex
    358
    Car cuts out over 4k RPM, seems to misfire. Hesitation
    Guys, dont know whats wrong with the car, maybe the coilpack but it's definaltly cutting out when i put my foot down hard, it just cannot handle it. If i build up slowly it seems to be fine.
    I disconnected the MAF for a few days but it was doing the same thing.
    Anyone else got any ideas, the engine Mgmt light flashed on and off the other day too but has not happened again since. Anyone else expeireced these problems. I dont think it's limp mode either.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Re: Car cuts out over 4k RPM, seems to misfire. Hesitation
    Coilpacks tend to make the car misfire throughout the rev range, and I've not wanted to put my foot down when mine went so I couldn't tell you if there is an effect on the rev limit. The EMS light was intermittant first time it happened to my S3.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Coilpack is most likely culprit!
    Feb 2006
    Bucks, England
    39
    My car was doing exactly the same thing at about 4k.rpm. I went to Audi and they said it was the no 1 cylinder coilpack so they replaced it for free.
    imported_gek
    If it is a coilpack, it will be logged.
    Have you got access to vag-com and then at least you can confirm it?
    Mo-S3's Avatar
    North West
    706
    While your in there also check the condition of the spark plugs just in case there is a problem with an electrode.
    Jul 2003
    Essex
    358
    oops, well i know it needs a service, massively overdue, i replaced one coil pack a while ago, cant remember which one unfortunately. So it looks like i'll have to change all of them
    cheers guys, anyone got any idea on the price of these and can i order them online from anywhere, time is a factor at the moment.
    Mo-S3's Avatar
    North West
    706
    if time is a factor then try and get over to a local audi or even a vw dealer and they will have them in stock. 99.9% sure of that. Very easy job to do yourself.
    Jul 2003
    Essex
    358
    sorted in the car park at work. got 4 new coil packs last night and fitted them today, it seems fine, but i'll be able to test it properly on the way home.
    when i spoke to audi and said i think one of my coils has gone, can they put VAg-Com on it and tell me which one is failing, they said yes but it will take an hour to diagnose. docklands Audi take the utter [img]/ubbthreads/images/graemlins/swear.gif[/img]. I just said [img]/ubbthreads/images/graemlins/swear.gif[/img] off its cheaper to buy 4 coils and replace them all.
    cheers anyway guys, you confirmed my hunch.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    I hope it turns out to be the coilpacks and not the MAF.
    PaulS3's Avatar
    UK
    1,003
    [ QUOTE ]
    [/ QUOTE ]
    10 mins, and some of that is getting laptop, setting it up, booting it up, making a coffee and a full scan.
    about 3 mins if you head straight to engine module and check faults,
    how do i know? Ive got full vagcom and last coil that failed i rang Audi assist and told them that it was a " random multiple missfire on cylinder 3."
    ADT was most impressed. [img]/ubbthreads/images/graemlins/lol.gif[/img]
    replaced all 4 free.
    imported_glen_jai
    Ok, I'm experiencing the same problem too. Cuts out at ~ 4k rpm.
    The car engine appears to operate fine, when being revved freely. The problem only seem to appear when the car is under load. So doesn't seem like a coil pack problem.
    Looks like a trip down to the dealer is on the cards.... <bugger>.
    UK
    289
    Coil or spark plugs always possible culprits
    When my coils have gone though, they have gone if you know what I mean - didnt ever happen over a period of time, car would just be undriveable. I had an intermittient misfire on my S3 for a few months once (hesitation/slight loss of power between 4k-5k rpm), new plugs solved it. Plugs are cheap too, so worth changing as a matter of course. The 40k spark plug service interval is too long, especially if your car is chipped imo
    Dunc
    imported_glen_jai
    Ok, car is misfiring big-time now, even at idle.
    Time to change a coil.
    Have to try one by one..... bugger!
    UK
    289
    coil then
    amb276s3's Avatar
    bird spotter
    Sep 2004
    Lincoln UK
    292
    Dont forget to check the condition of the four coloured wires leading into each coil pack, over time they become brittle and the insulation starts to crack, this gives the same symptoms as a faulty coil pack
    Jul 2003
    Essex
    358
    Mine was on and off, idle was fine, but under load was when i experienced the problem.
    I changed all 4. cheapest way. did it in the car park at docklands audi, they wanted to charge me 1 hour diagnostic.
    imported_glen_jai
    Cheers for the advice chaps.
    Coils are such a nightmare on audis. Guess I should really changed them all to stop it happening again.
