Volks AutosJMB Retrofits
    mini-si's Avatar
    Apr 2014
    61
    Ah FMIC how long to fit
    Hi all.
    I am am finally the proud owner of a mint Ming blue s3. It is running a stage 1 map at present. Looking at putting a FMIC on it this week to keep things cooler with summer on its way.
    am looking at the AH inter cooler. My questions are
    what pipe work do I need? Bends etc and where's best to get from?
    also is there any supporting mods worth doing at the same time?
    down pipe maybe? Is that a front bumper off job aswell.
    Would I require a further map, stage 2 maybe if I go down pipe/ front mount.
    Thanks in advance.
    Its andys old car from the forum user name AJC
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,266
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Hi there,
    All the answers to your questions can be found here -
    A3/S3 FAQ / How To's / Tuning Info STICKIES - PLEASE READ BEFORE POSTING
    You will find the AH FAB V2 details in there- and if you look through Tufftys build thread he has a detailed description of how to fit it - I mean he is the guy that worked with AH Fabrications to create it in the first place.
    After any mod you could argue that a remap or remap tweek is needed tbh.
    DP is a pig job to do but most restrictive item on the exhaust side of things and if you don't go for a Pipewerx one then the Relentless one can sometimes cause issues when fitted.
    A Full spec of the car would also be ideal dude.
    Fitting time- it all depends on how handy you are with a spanner and how well you know your way round a 1.8t.
    Use the search bar at the top right as what you are asking has been covered many times, with details on where to buy the products you require and with step by step guides. Ebay is good for the FMIC bits and pieces and site sponsors for the other items.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    mini-si's Avatar
    Apr 2014
    61
    Cheers for the reply. Have actually read that post about FMIC fitting before just forgot about it. Lol. I'm new to the 1.8t engine and Germans cars altogether. I'm quite handy with the tools as I've worked on a few cars in the past.
    I reckon just the FMIC to start then. Hopefully this won't cause any issues with the stage 1 map???
    I plan on going hybrid, forge rods etc in the future. But just want some decent cooling for now.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    FMIC is easy and you will find the 1.8t a pleasure to work with,that and the 2 litre newer one are very good to tune.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,266
    Quote Originally Posted by mini-si View Post
    I'm all ears for the answer on this tbh also....
    2000 S3 APY
  1. How long to fit forge split r valve?
    By 02audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2009, 17:29
  2. How long to fit new suspension?
    By Dansmith in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2009, 06:06
  3. How long to fit a new turbo?
    By GarryA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2006, 07:41
  4. Droplinks - how long til they fail ?
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:34
