Badger5Sky Insurance
Results 1 to 10 of 10
    Feb 2014
    112
    All whoosh and no go
    So after a while suspecting my s3 of being a bit underpowered i replaced the vac lines etc with silicone, replaced the dv and put a silicone TIP on. Didnt make a whole lot of difference.
    When i unplugged the N75 the car ran nice and smooth but was of course underpowered.
    When i unplugged the MAF the car ran at its best so far. I bought a generic MAF and put it in and quickly realised that it was pure ****e. The idle was lumpy and the the drive was undriveable.
    I got my hands on a replacement bosch one now and it seems to be good BUT...The delivery of boost without the MAF plugged in was still much better, with it plugged in there are still occasional moments of hesitation combined with lots of whoosh and no go..it does sound lie an intermittent boost leak.
    any ideas?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    889
    Add Vex182 on Facebook
    Scan for fault codes first just to make sure.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Feb 2014
    112
    this is what i get
    Address 01: Engine Labels: 06A-906-032-BAM.lbl
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT G 0004
    Coding: 10710
    Shop #: WSC 33278
    VCID: 387513E1180774DE637-5140
    WAUZZZ8LX31208933 AUZ7Z0B2170434
    3 Faults Found:
    17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
    P1560 - 35-10 - -) - Intermittent
    17861 - Exhaust Gas Temp Sensor 1 (G235)
    P1453 - 35-10 - Open or Short to Plus - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    Readiness: 0000 0000
    Vex182's Avatar
    Apr 2012
    Hinckley
    889
    Well the engine speed is usually down to the car revving very high, is it mapped? The EGT sensor is important, get that looked at ASAP as the Ecu can't monitor the exhaust temp so it dumps fuel in to help cool itself - it will think it's to hot. The last fault usually comes from having the battery disconnected.
    Feb 2014
    112
    I dont think its mapped. The previous owner never mentioned it and its my first s3 so i dont really know what it should feel like if it was mapped.
    As for what you are saying about the car thinking its hot........ i have noticed that if i park the car up for a few hours then get back in an drive it, the tamp gauge goes straight to 90 degrees in a matter of seconds. could this be related?
    Vex182's Avatar
    Apr 2012
    Hinckley
    889
    Yes if the EGT sensor can't get a reading, it just think it's hot and dumps in fuel. Your fuel economy will be pretty poor, I've been there! That sounds like the coolant temp sensor is not reading correctly. After a few hours it should have dropped to below 90, if not down to 60. A bad coolant temp sensor will affect the overall running of the car too.
    Feb 2014
    112
    when i bought the car, the gauge always sat just under 90 but from what i read, if its not sitting at 90 theres something wrong, so i changed the stat and it sits at 90 now.
    Im guessing a faulty EGT will affect power too?
    also, is there any way for me to find out if my car has been mapped?
    gregor571's Avatar
    Nov 2010
    Slovenia
    68
    Do some logs with vag-com & post them.
    Feb 2014
    112
    sorry, im trying to learn about logging. I have VAG-COM and cable. What should i be logging specifically
    gregor571's Avatar
    Nov 2010
    Slovenia
    68
  1. Car just looses all power and stops for a split second......
    By 0morg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2011, 21:45
  2. To all Remapper and others
    By Tobez in forum Tuning
    Last Post: 17th March 2006, 20:41
  3. All revs and no go. Please help!
    By S3Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2005, 08:34
  4. Todays pictures, all clean and looking good!
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 12:59
