JMB RetrofitsSky Insurance
Results 1 to 12 of 12
    May 2014
    7
    S3 Airfilter Heat Advice
    Good Evening all,
    I have very recently purchased my self a 2003 S3 and straight away fitted a pipercross cone filter (as its one of the few things I can do myself). I was really chuffed with myself until I showed one of my friends, who said "those engines get bloody hot and thats just going to be stucking hot air in" ...
    Is this true? and if so what is the best next step?
    Jake
    Looking for parts :P
    Dec 2013
    Bury St. Edmunds
    68
    You can fit a heat shield, there are some on eBay, but they are not a necessaty, a friend of mine has his S3 running 360bhp without a heat shield and he has no overheating problems. I fitted one just for good measure
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Its what your intercooler is for... the temps of the air coming out of the turbo preintercooler can be 150 degrees... not really gonna make loads of difference in the grand scheme of things...
    However... foam filters aren't the best... they need to be oiled quite a bit to be effective and this oil kills MAF sensors...
    Also looks like the one you have fitted has a neck size smaller than the MAF.. this can funnel the air over the MAF sensor causing it the read incorrectly... most cone filters fit over the end of the MAF
    <tuffty/>
    May 2014
    7
    Thanks both for the replies.
    tuffty, what other options did I have? I rushed this decision being the impulsive tool I am.
    If the MAF was to read incorrectly, would this affect the car in anyway?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    If you had more pipe between filter and maf you'd probably get more uniform and accurate airflow over the sensor.
    but the inlet on the filter should at least be the same size as the maf tube I.D.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    While an heat shield as said will have arguably no effect, what it will do is hold the MAF steady for correct readings..
    May 2014
    7
    If the MAF in reading incorrectly does this affect the performance of the car?
    Jake
    May 2014
    7
    Also does anyone have or could send me in the direction of a picture of what a filter should look like fitted properly?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Quote Originally Posted by S3Jake View Post
    Like this.
    Dec 2013
    Bury St. Edmunds
    68
    Yep that ones the same as mine.
    Aug 2011
    Plymouth
    761
    Add Lavis89 on Facebook
    A maf reading incorrectly will affect your fueling so will effect the performance
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Vent pod boost gauge, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave (RIP) adjustable tie bars, FMIC
    Soon to be done: SAI delete, 3" Catback, Stage 2 remap
    May 2014
    7
    Would I be able to feel it driving if the MAF was reading incorrectly?
    Hopefully attached is a close-up ... worth replacing it?
  1. URGENT ADVICE NEEDED/WANTED REGARDING COOLANT/HEATING IN TDI A4!
    By polo10v in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st October 2011, 21:47
  2. Heating doesn't seem to be working correctly - advice?
    By gadgesxi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2010, 18:46
  3. Recaros - are they already heated?
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2005, 17:46
  4. CD Burner Advice
    By Moresauce in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 31st January 2003, 12:05
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
