Volks AutosEM Tuning
Results 1 to 27 of 27
Like Tree1Likes
  • 1 Post By Prawn
Thread: Corbeau Revolution bucket seats
    Oct 2013
    29
    Bought two corbeau Revolution buckets seats yesterday at bhp show in Kent.
    Just a question regarding mounting. I have bought the side mounts but can I mount onto standard mounts in car of will others needed to be bought?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    there are really two options for you at this point mate.
    You can either buy some car specific subframes, which will allow you to use your sidemounts on the car specific subframes and into the car.
    Otherwise, it's a carpet out job and weld in some proper rails to bolt them to, which is a pretty big job.
    Feb 2012
    1,106
    Lose the oem mounts. It can be done this way but you still fairly high and the oem mount doesnt sit level so you will lose 2 -3 of your adjustment holes in the side mounts leveling the seat up.
    If you are able do weld in bars do them. Its a better job in all ways.
    mines on oem subframes for now. Not keen on it. no room under the seat for your hands to adjust harness's and still fairly heavy.
    Oct 2013
    29
    Joy of building a track car.
    Do you guys know if it is illegal to drive to Road with bucket seats that have side head supports?
    Dec 2013
    131
    On my old track car, I built my own subframe that picked up the original bolt holes, then bolted my (home made) side mounts to that,
    Was probably as low as you could even get it on bars.
    Feb 2012
    1,106
    Quote Originally Posted by NathanGlover View Post
    After doing lots of research seat and harness related i found that its a very grey area and dependant on mot test centres. I very much doubt you get any bother elsewhere. Prawn has head protection on his seats and its a road going car
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Absolutely not illegal mate. not at all
    I run Cobra Sebring GT's in mine and have had no issues what so ever:
    Also, if you're building a track car, do it properly from the off. Cut out the old rails and weld in bars properly to FIA spec
    CMcKenzie likes this.
    Oct 2013
    29
    prawn I'm going to apologise now for the amount of things I'm going to be asking you in the coming weeks for this project
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,063
    Visit 16Klappe's Instagram Channel
    Read and research.
    Prawn writes fantastic reports on his car with loads of detailed pictures and information, if you have the understanding to do the job it should all fall into place. I love reading through his thread and recapping things that were done.
    Have you done a track day yet? What state of tune is the car now?
    I quite often say I'm going to do things.
    Then never do them.
    Oct 2013
    29
    The engine is where I want to leave it atm. Suspension is done just need strut braces front and rear. But cage is going to be the next issue. Never build a track car before.
    I'm going to be drivibg this stripped out car as my daily.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Very sensible, you really won't regret it! getting the car safe is a big deal, decent seats, properly mounted are a must. Sounds like you've done the first bit right with good seats, I'd finish it all off nicely by mounting them on proper rails
    I think I did a post on this a while back, I'll see if i can find it.
    Also, providing you keep your door bars low at the front, it'll be surprisingly easy to jump in and out daily, and you'll be amazed at how non offensive it'll be inside too. mine's really not that loud at all even with everything removed.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Really really ancient pic, but it gives you an idea of access with low single door bars:
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Shamelessly found an old post, which was a copy of an even older post I wrote about installing buckets in an 8L:
    Here's what I previously had to say about bucket seats, shamelessly copied from an old post of mine:
    How they're mounted properly:
    Cobra Monaco Pro:
    RMD Maximum Protection (Haha - *** yea right!?!) from Rally Design:
    They didn't end up so well. Anyone spot the issue?
    Don't buy cheap seats people:
    Then it was time for some proper seats!
    Cobra Sebring GT - ProFit
    And a few previous posts about seats which might help you out here:
    Bucket seat pic request/help
    Bucket seats. How hard are they to make fit?
    bucket seats in s3
    I also did a write up on the cage install too, give me a shout when you get to that point
    Feb 2012
    1,106
    Who did your weld in bars nick?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,063
    Nick did. With some regulation thickness box section, the dimensions and thickness are in the links.
    Then never do them.
    Aug 2011
    Plymouth
    744
    Add Lavis89 on Facebook
    if i ever decided to track mine i know who im asking
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Quote Originally Posted by daz-20vt View Post
    As Jardo said, I did.
    30mm x 3mm wall box section, and 3mm thick steel end plates, to 40cm² minimum. 50x80mm in my case.
    I could do yours too at some point in the future if you ever wanted to re-mount yours Daz, just not in a position where I've got the time at the moment or I'd have offered to help to save all your recent hassle!
    Nov 2013
    108
    I don't know if I could cope with full harnesses on a daily, I always drop stuff in the car and you can't reach anything.
    Last time I took I had to use a full track car on the road for a few days was an entertaining nightmare. Changing lanes on the motorway is a bit Kamikaze since you can't check your blind spot.
    At least on track you have the co driver checking for lapping traffic when you merge on track from a staggered start.
    Feb 2012
    1,106
    My brains made of mush i could have sworn you said you had them done by a friend.
    Defo up for changing mine when ever you can fit it in. No rush as they are in and are safe but I hate it on oem mounts.
    of course be a decent drink in it for ya!!
    But for anyone reading id only recommend how prawns done it.
    much more professional finish
    do it right do it once!!!
    Feb 2012
    1,106
    Quote Originally Posted by antwan64og View Post
    i agree with some of this. Ive never felt i cant see enough tbh. Just make sure you check mirrors regularly enough. However it does take me 5 mins to get to a point of being able to pull away, time ive fitted the harness and refitted it due to leaving my phone and wallet on the dash lol.
    would 100 percent never go back though. Its totally made the car for me. Hated it oem. Love it empty!! 2k miles a year for me though!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Had help with the cage welding, simply because mine wasn't neat enough back then. Seat rails I did myself on Christmas day and Boxing day 2010!
    We'll find time for yours mate, so long as you're not in a tearing hurry
    Feb 2012
    1,106
    Your a top man nick!!! Will get there for sure i know. No biggy just a better job long term as you well know
    Oct 2013
    29
    I'm removing the front seats today just a quick question will the air bags go off if I undo the cables below the seat?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    no, they won't mate. but the light will come one after they're removed
    Oct 2013
    29
    how did you get the seats off the roller on the inside?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    remove the plastic caps on the backs of the rollers, single hidden screw in each. The seat then slides out backwards once you've undone the 2 front m8 bolts in the centre
  28. #27
    Oct 2013
    29
    Thanks for the last reply prawn.
    Cars been in the garage for a week now getting them put in. I'll post pictures on Tuesday of when it comes back.
    Do you know how to remove the rear seat belts to put the mounting points for the harnesses?
  1. s3 bucket seats
    By audi_driver in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2007, 00:12
  2. S3 Bucket Seats
    By Spook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2007, 09:47
  3. New S3 bucket seats
    By AL_B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th March 2007, 19:08
  4. Optional bucket seats on S3
    By newbiecrg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2007, 17:53
  5. S3 Bucket Seats
    Last Post: 4th November 2006, 13:45
