    Oct 2012
    Stockport
    34
    Smoke when going down hill. Also rough idle and cold runing
    My car ran perfectly with just a stage 1 remap then I did a stage 2 conversion on it and now I have loads of grey and blue smoke coming out of the exhaust but only when going down a hill and only at low (below 2K) revs, also if I brake hard which clears on the flat after a few seconds.
    Normal driving on the flat or going up hill is fine, no smoke on idle or when booting it.
    AND
    Since stage 2 I've also got a very rough idle, sound like I'm revving the car.
    AND
    The power cuts out between 1.2k and 1.8k revs especially when cold, it's un-drivable cold.
    No codes showing, I did a home made smoke test and no vacuum leeks showed.
    Smoke = Turbo or Rings?
    Idle and running = ???
    Audi A3 1.8T 2001 AUM - Custom Stage 2 Map. 3" De-cat Downpipe, 2.5" System, 100mm SMIC, CAI, BKR7E Plugs, Forge Recirc Valve. Uprated Clutch with Lightened SM Flywheel. SAI, N249 Removed, Simplified PCV with Oil Catch Can, Silicone Vac and Boost Hoses.
    Seat Altea 2.0TDi DSG 2004 BKD - Custom Stage 1 Map. Now with new Engine, Turbo, Intercooler, Piping and Radiator (due to Turbo failing and dumping bits into the engine)
    Essentials - VAG-COM. WinOLS.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Breather system blocked? do you have a catch can?
    Oct 2012
    Stockport
    34
    I fitted a new catch can with new pipes about 500 miles after doing the conversion. I had a 15mm and fitted a 19mm.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    just let it vent to atmosphere and see if it helps,
    Oct 2012
    Stockport
    34
    Tried vent to atmosphere and no difference.
    Could the power cuts be something to do with wastegate actuator. When the power cuts I can hear a sound like air dumping or turbo spooling but its not the recirc' valve, tested without it.
  1. A4 tfsi rough idle and fails to start
    By Smythe in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 30th October 2013, 23:20
  2. Very rough idle and emission light on 2.0 FSI
    By cunni319 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2013, 13:36
  3. Faulty servo going down hill ???
    By 666markyboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2012, 17:40
  4. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  5. Rough idle and slight backfire!!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2008, 15:22
