Chris NottVolks Autos
Results 1 to 8 of 8
    Dec 2013
    Leaking some sort of liquid (heater)
    Hi yesterday when i parked up as engine was cooling i popped the bonnet and noticed there was liquid am guessing was water. Just droplets coming down heaters were on . So i turned the heating off and the drops stopped any ideas how or whats going on there ?? Dont know how else to explain this sorry
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Air con normally causes this... end up with a damp patch under the car... its normal (assuming this is the issue)
    If it was a coolant leak it should be pink (Assuming you have G12 as coolant)
    <tuffty/>
    Dec 2013
    If it is the air con is it anything to worry about . Dont think i had air con econ switch was off
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    If econ is 'on' (red led indicator is lit) then air con is 'off'... is this what you mean?
    <tuffty/>
    Dec 2013
    No icon is not lit. Dosent that mean its not on .?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by c3jys View Post
    Press the econ button... if the switch's LED lights up then aircon is off... if its not lit up then aircon is on... please note this only swtich's the aircon compressor off/on... you can use Auto in ECON mode which means you have climate control but its not using the 'aircon' system to provide the cool air...
    <tuffty/>
    Dec 2013
    Will have a look thanks
    Dec 2013
    Yes the light does lit so all this time ive been drivin with aircon on lol. So when its a cold night the econ switch shud b lit. Bit confusing this
  1. Is this some sort of scam?
    By Caesium in forum General Automotive Chat
    Last Post: 16th January 2010, 22:58
  2. Some sort of knock through the steering
    By ex_scoobydoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 15:29
  3. Some sort of leak
    By b19rak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2007, 19:23
  4. just bought an s3 and im interested in purchasing some sort of vag cable.
    By nky_84 in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th April 2007, 19:24
  5. This some sort of sick joke...???
    By silver75 in forum General Chat
    Last Post: 3rd December 2006, 10:32
