Lost a bolt from the exhaust manifold / turbo join, can anyone help with the part number please, car sounds like a tractor!
Audi couldn't find it as they said it was a stud and nut?
06A-145-540-K Turbo Mounting Bolts (Inverse Torx)
That Should be the one and you will need one of their special washers which I can't find the part number for but they should find that with the bolt if iirc the bolt is about 7quid and the washer about 8quid
Hope that helps
