EM TuningJMB Retrofits
Results 1 to 8 of 8
    Mar 2013
    31
    A3 312mm Brake upgrade
    Been looking into this and from memory you just need calliper carriers and 312 discs but this lead me to wonder how it improves braking.
    Am I being really stupid in saying if you're using the same pads, you're biting on the same amount of disc so shouldn't increase stopping power?
    Or is it to do with cooling?
    Apr 2014
    Portsmouth
    137
    A larger disc has a larger mass so therefore increases the time it takes to heat up and secondly a larger disk with the calipers spaced out provides more braking force as you are pinching further away from the centre of the hub thus giving more leverage if you catch my drift
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Larger disc = more leverage for same effort...
    <tuffty/>
    Dec 2013
    131
    If you upgrade, to offset the cost I'll purchase your old carriers
    Mar 2013
    31
    Gotcha! Cheers
    Gary: Depends how desperate you want them, I may not upgrade for a couple of months! Can bare you in mind if you like, pm you when i do it?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    I have a set of 312mm carriers if anyone is looking for some PM me for info
    J44KWED's Avatar
    Sep 2013
    West London
    46
    I have a pair of callipers off my 8L 1.8T 1998 AGU. PM me if interested too!
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    I have a set of callipers with carriers also have hel braided lines, brembo max 312 discs and ds2500 pads all for £120 pm me if ur interested would have to collect or arrange courier
  1. 312mm Brake Upgrade - Same pad size same surface area??
    By sekenzo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2010, 22:16
  2. 312mm brake upgrade advice!?
    By MAD_Adamski in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2009, 12:09
  3. 312mm brake upgrade
    By Shug1874 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2009, 16:15
  4. 312mm Brake Upgrade - How To?
    By MikeA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2007, 13:50
  5. My 312mm Brake upgrade.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2005, 22:45
