EM TuningMonster Motorsport
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By leegsi
Thread: ABS light. what light??
    Apr 2014
    Aldridge
    11
    Basically when I turn my ignition on I dont get my abs light come on. I have run a scan with vcds and p1851 came up and 2 front abs sensor's. I originally thought my master cylinder had gone but upon further inspection someone had filled the brake fluid up with what looked like atf fluid. So I went to run a abs pump bleed and it worked evan though that error code came up. I checked all fuses and there all fine but the light still doesn't illuminate evan under a instrument cluster test through vag com. Are these abs bulbs prone to failure? ?
    benashley's Avatar
    Jan 2014
    Cornwall
    59
    Bulb may have been removed because of the faults?
    Instrument panel is easy enough to remove to check the bulb
    Apr 2014
    Aldridge
    11
    Checked inside the cluster looks like its a neon/led fixed to the board. There was 3 removable bulbs 2 missing but could see they wasnt abs anyway.
    Lewis583's Avatar
    Mar 2010
    872
    Some unscrupulous person may have done the old electrical tape on the inside of the cluster trick to mask the light being on.
    You will probably find that they haven't put ATF fluid in, the brake fluid just hasn't been changed in ages and has gone dirty.
    Clear the faults, drive the car and rescan to see what returns.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Apr 2014
    Aldridge
    11
    I did think that aswell but ive have to cluster in bits and couldnt see nothing. I tried another set of clocks we had of another a3 lights came on but obviously wouldnt start the car and because the part numbers were different I dont think I can code them in. Can someone with a 98 a3 1.8 sport please tell me if ther ABS buls is removable or is it part of the circuit board ??
    Mar 2013
    Devon
    622
    Quote Originally Posted by wsdizzys3 View Post
    Its a surface mount LED, need to be confident with a fine tip soldering iron to change it.
    They don't usually fail, I suspect some one has sabotaged it with electrical tape as above or deliberately damaged the track on the PCB.
    Aug 2009
    Kent
    70
    is this the UKNSI part?
    Apr 2014
    Aldridge
    11
    Quote Originally Posted by myke View Post
    Not sure lol how do you find that out. Looks like im gonna be getting new clocks or buying a fine tip soldering iron. Does the part numbers have to match or can I use a 140mph clock instead of a 160mph clock. It plugs in pits in and lights up ok just not sure if im codimg it right or if its just not allowing me to code it because its the wrong part code
    Sep 2013
    Portsmouth
    249
    Shine a torch where the led would shine as you can put tape between the speedo mat and the clocks itself.
    Also try putting the clocks back in so you can see the bulb illuminate and if it doesnt push on the led to see if there is a dry joint
    Apr 2014
    Aldridge
    11
    Quote Originally Posted by leegsi View Post
    Tried it mate had the clocks apart. Done a instrument panel test on vcds nothink. Might just have to get new clocks
    Sep 2013
    Portsmouth
    249
    Are you near Portsmouth as I could solder a new led in if its that.
    Apr 2014
    Aldridge
    11
    Im in walsall mate. How much do you charge?
    Sep 2013
    Portsmouth
    249
    If you were local and had the dash out with new led nothing.
    westcoast a3 likes this.
  1. Adaptive Xenon Lights - what are they like?
    By WolvesPhil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st November 2008, 09:17
  2. Glow plug + ABS + ESP Warning Lights
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2007, 16:44
  3. Warning light-what is it???
    By S3K in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2006, 19:50
  4. Flashing interior lights - what does it mean?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2005, 19:59
  5. What light blubs does an A3 take?
    By imran_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2003, 09:29
