AH FabricationsChris Nott
Results 1 to 14 of 14
Thread: Audi S3 MAF
    Feb 2014
    112
    Audi S3 MAF
    Sowhile trying to sort some running issues, i discovered that when i unplug my MAF the car runs waaaaaay better. I ordered a new one and plugged it in and it runs worse than ever!!
    Is there something i need to do after i plug the new one in? do i need to do a throttle body reset? and if so, how do i go about it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Scanned for fault codes? should always do that before spanking money tbh...
    Fault codes are documented here
    Category:Fault Codes - Ross-Tech Wiki
    <tuffty/>
    epox's Avatar
    Oct 2012
    Glasgow
    600
    Did you get a Bosch Maf from tps? As this is a must don't use eBay or eurocarparts as they are crap.
    Mark
    S3 2003........REVO..........Stage 1...........218G/S.......÷..........°8..........=..........272bhp ......368Nm.....271 ft lbs
    Feb 2014
    112
    hmmm maybe thats where i went wrong as it isnt a bosch one..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    As long as its a Bosch one then you should be fine... I have used Bosch sensors from GSF and ECP as well as TPS and all run fine... non Bosch ones as already said are actual rubbish...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    ...but scan for fault codes all the same.. preferably using VCDS
    <tuffty/>
    Freeman_1986's Avatar
    May 2013
    Forest Of Dean
    I've had 2 Bosch ones from ECP. Both were crap, so I just have it unplugged now. It may use a bit more fuel that way, but runs better and CBA with the hassle....
    S3 AMK (AKA FUTURE CLASSIC )
    Mods So Far: PCV Delete, N249 Bypass, S2K Filter, Black Side Indicators, FMIC, B5 TIP, Rear Anti Roll Bar, Polybush Upgrade.
    Mods Wanted/Planned: Wheel Spacers, Moar Silicone, 3" Downpipe, Decat, Debadge Rear Rings, Spray Front Rings, 8P/V Gear Knob, REVO!!!!!!!
    MISC: Sort Out Paintwork...
    Because It Makes No Attempt To Be Great, It Is Therefore Extremely Great.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Have heard of rouge ones from ECP... generally get mine from GSF to be fair as ECP never seem to have stock... my current MAF sensor is from GSF..
    <tuffty/>
    Jun 2013
    86
    While you're on the subject...
    How do I get the MAF out the holder? I thought the 2 screws were security torx but I've tried a few from T20 to T30 I think but they won't quite fit in. Are they Torx?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    5 point security torx...
    <tuffty/>
    Feb 2014
    112
    i tend to just dremel a slot in to them and use a flat head screwdriver to remove
    Jun 2013
    86
    hmm sounds like Torx bits come in differing point counts then
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Quote Originally Posted by LynxE View Post
    Silverhill 5 Point Star Torx Bit Set (10 bits): Amazon.co.uk: DIY & Tools
    <tuffty/>
    Jun 2013
    86
    Thanks. Can go back to cleaning my MAF this weekend
  1. Wanted Audi S3 MAF
    By goodbuzzman1 in forum For Sale/Wanted - Audi Parts
    Last Post: 18th April 2014, 11:03
  2. Audi S3 MAF readings
    By Agric04 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2012, 09:05
  3. Audi S4 Maf, Badger,Tuffty,Welly
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2012, 22:29
  4. AUDI A3 AGU MAFS
    By a3Nate in forum For Sale/Wanted - Audi Parts
    Last Post: 30th December 2011, 16:37
