EM TuningAH Fabrications
    Apr 2014
    Portsmouth
    138
    Puzzling oil light problem
    Hi all this is my first thread here I have had my nice shiny s3 for about a week now and after 2days I had the red dripping oil can
    being fairly familiar with the vag 1.8t engines (last car was a mk4 golf gti) I had the sump off cleaned it up and fitted a new oil pump and pickup pipe along with full oil and filter change after all of this I start the car and gently run it to 2k rpm for a few seconds and the bloody light comes back on I really don't know what else to do
    is there a way I can bypass the pressure sender (just to be able to rule out a wiring fault)
    Apr 2014
    Portsmouth
    138
    Forgot to mention it is a 1999 apy engine code
    Lewis583's Avatar
    Mar 2010
    872
    You could disconnect the spade terminal from the pressure sender and earth it while revving. Though I only suggest doing that after you have mechanically checked the oil pressure with a gauge.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Apr 2014
    Portsmouth
    138
    Thanks for the reply I'll have to go find a pressure gauge tomorrow and give that a go also my VAGCOM cable should arrive in the next 2 days so hopefully I can find the cause of this I'm in over £150 already trying to sort this lol
  1. audi a3 1.8t quattro sport 2002 oil warning light problem
    By spencewatts in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2013, 21:01
  2. Help!!! Oil Light Problem on A3!!!
    By johnnysalv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2010, 09:25
  3. Oil Warning Light Problem, HELP 1st ever Audi
    By vinceremedy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2010, 15:20
  4. Oil light warning resulting in toe home, anyone recognise this problem?
    By sam_20vturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2006, 19:02
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
