Sky InsuranceEM Tuning
    Apr 2014
    12
    Rear Shock Issue? - Best Replacement Options?
    First post on here but owned my s3 for 3 months and used some guides on here. Been going round the car renewing the suspension bushes including front wishbone bushes and top mounts.
    After replacing the front bushes I'm still getting a knocking from the front passenger side and a knocking from the rear area. I took the car for a free suspension check and they advised the rear springs were snapped, I ordered some replacement and got on with changing them out, only to find they weren't snapped!
    I did find that the nearside rear shock had some play between the top and bottom but dont really have anything to compare against. It also had some score marks down one side, but its operation felt ok.
    Now I'm not sure wheter to go down the aftermarket or standard replacement route, also what else would you recommend to replace at the same time as the struts and springs?
    If I was to go aftermarket I was think Koni STR.T Struts and Apex Springs or am I better off savings for the Bilstein B8s?
    Mar 2013
    Devon
    614
    I have Koni STR shocks, really happy with them. I would go for Eibach pro springs over apex though.
    Did you replace the inner anti roll bar bushes? I would check the drop links for play, these are the most common cause of front end knocks.
    Apr 2014
    12
    Cool thanks, I'll check them when I have a chance . Can you replace the bushes without changing the arb or is it a matter of checking when your there?
    Did check the drop links for split gators, seemed fine, is there any better way to check for play?
    How do the koni shocks ride? Are you running the eibach springs, seem mixed reviews regarding the rear ride height with them...
    Oct 2012
    434
    I had clonky kind of sound on my tdiq changed shocks and clonk gone, i am now going to do the droplinks and arb bushes as i found some play /loooseness in the droplinks and it won't hurt to do the arb bushes afte 150k either
    Apr 2014
    12
    Yeh will probably give those a go then as they're not too expensive and the get some springs and shocks on. Trying to avoid paying for multiple wheel alignments so want to get it right first time.
  1. Audi A4 B5 estate Rear shocks and coils replacement
    By Johnjones in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2013, 23:03
  2. Leaking Shocks - Replacement Options?
    By motionpotion in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 16th September 2012, 18:23
  3. late spec issue with lower rear shock mounts
    By nwmlarge in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2011, 21:14
  4. Replacement Rear Shocks required
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2008, 20:42
  5. Rear shocks being replaced
    By missviper in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2006, 15:25
