AH FabricationsEM Tuning
Results 1 to 11 of 11
    Jan 2014
    78
    Exclamation need piston rings stem seals and a turbo
    as title wheres the best place too buy all these from? its for a 20vt bam engine?
    had nothing but problems with my s3 since i bought it and now its just constant blue smoke out the exhaust! at first it was just on start up but now it just happens constantly on idle not so much when driving but occasionaly when driving but funny thing is keep checking the oil and it doesnt seem too be using any. totaly confused so its going too my mechanic tomorrow for him too have a look at turbo for play and check stem seals. he thinks it could be either stem seals,piston rings or turbo.
    was trying too think of what could have been the cause of the problems the mods i have done since owning are:
    decat
    pcv delete
    n249 bypass
    s2000 air filter
    and since owning i have done the following:
    oil and filter change
    new lambda
    new spark plugs
    anyone got any other ideas of what could be the cause?
    Jan 2014
    78
    anyone know where i could get stem seals from?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    ebay, ecp, gsf dealers? Supertech
    Jan 2014
    78
    And once I have the head of what would I be aswell too replace? I know timing belt head gasket and head bolts but what else?
    Jun 2013
    14
    I got mine in a complete headgasket kit from Victor reinz on German eBay and it all seemed like quality parts.
    Jan 2014
    78
    morten do you think this is the same one you got? it doesnt state thats for bam engines tho
    AUDI A3 S3 A4 TT CYLINDER HEAD GASKET SET 1.8L TURBO CHARGER 20V ENGINE COUPE | eBay
    Mar 2013
    Devon
    405
    Elring is an OEM supplier, a complete Elring head set can be picked up from Euro Car Parts for around £45
    I once fitted non OEM valve stem seals to a VW Diesel engine and had to rebuild the head again a year later when they started passing oil. I I wouldn't risk it again.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Id say stem seals. Mine been the exact same for nearly 2 years. Engine still pulls like a train, makes 16 psi peak on standard map and doesnt use much oil. Im just waiting for it to go pop then rebuilding it.
    Jan 2014
    78
    Cheers for the advice lads! I've been offered a set of genuine stem seals so will be taking them but can someone give me a little list of things too replace while the heads off?
    Jun 2013
    14
    Quote Originally Posted by Bennys3 View Post
    It's the same items, but mine showed the complete package from Victor reinz in unopened condition in the add. I bought it from cs-parts-de.
    Also, remember to buy grease for easy fitting
    Lewis583's Avatar
    Mar 2010
    834
    I would recommend changing the water pump while it is in bits along with a full timing belt kit (tensioner damper/tensioner/idler). £30 and 3 bolts for the water pump and another 3 or 4 bolts to swap the tensioner/damper/idler.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. Part numbers needed for Injector seals and return pipes & various other PN needed
    By madhoose in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2014, 13:31
  2. how much to replace these pistons and piston rings then??
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2012, 08:04
  3. Replies: 0
    Last Post: 14th September 2011, 11:49
  4. help please...turbo or piston rings
    By kooch_481 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2010, 20:10
  5. LLTEK's new D-BOV for Audi, and stock turbo
    By rafA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th February 2004, 14:27
