****ty charge pipe off the turbo (specially if it's "quick clamp"), cracked intercooler... Could be anything really, worth going to a garage with a smoke tester if you think you've deffo got a leak. Are you getting a fault code?
I would take it to a garage to get it smoke tested if I could find one near me that had a smoke tester.
The only related fault code I'm getting is:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V)
P1297 - 35-00
But this code has only just started showing up and I've had this problem before it showed up.
What's making me think I have a leak is because when I put my foot down I can hear the turbo spool up but I don't feel the extra power kick in like it did before and also my boost gauge only goes from -20 to just over the 0.
I've been thinking about doing a day pressure test but can't find a good enough guide showing where to put it and what to block off.
