Monster MotorsportChris Nott
Results 1 to 18 of 18
    Oct 2005
    uk
    315
    Aircon Compressor failed :(
    Hi
    My 99' S3 aircon no longer works, I was told before I bought the car that the bearings were failing on the compresser, now the clutch no longer engages.
    To buy this part from Audi is very expensive, I've found a place that sells them slightly cheaper and I think a second hand one would be a waste of time.
    Does anyone know the part number?
    The part number I have from Audi does not seem to match up [img]/ubbthreads/images/graemlins/frown.gif[/img]
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,524
    Re: Aircon Compressor failed :(
    Silly question I know, but how do you know it doesn't work?
    The compressor clutch won't engage if the outside temps are below 5 degrees, so the ice symbol won't come up, but if you have tested the mechanism by another means, disregard what I have just typed.
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Sorry for hi-jacking, but jojo, this may explain something that was baffling me.. my randomly working air con! Someone i know with a 1.8T said they defrost their windscreen with the air con in the morning, however whenever i try the air con wont come on, the ice symbol flashes up, and goes. Is this because of the reason you stated above? i still don't understand how he manages to defrost his windows but my wont. Cheers
    Ross
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    my AC Compressor is screwed...when it engages, i sends horrendous vibrations through the car...not sure if its ceased or what but its fooked either way! lol
    Rich
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    Your car sounds like its heading the way of mine Rich, I finally got mine over to Fontain this morning to get the steering sorted. [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    ...Watching you!
    Earlsfield, London
    5,087
    Lol..i hope not!! hahaha. My steering doesnt seem to be getting much worse, but will need sorting at some point in the not to distant future!
    Rich
    Oct 2005
    uk
    315
    Well it was making noises from the comp, but now the clutch does not even engage, problem is not getting the work done by audi you don't know what compressor it has, as the same one from other Vags cars will fit.
    Just hoping I can see a part number without having to take it off [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Not too bothered about the aircon but if I don't have it fixed now I never will, black with black leather will get toasty in summer too [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Oct 2005
    uk
    315
    Arrrr just read this
    Dam it's too cold to test, I still can't see it working without making a noise though, any ideas what the part numbder may be?
    Feb 2004
    331
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    Same here... mine makes a horible grinding noise when on... for the time being I'll just keep it off.
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    [/ QUOTE ]
    I've disconnected the plug from it too...but the bloody thing still engages when i accidentally turn it on.
    Rich
    Feb 2004
    331
    Yeah I thought about trying to find a more permanent solution rather than turning it off every time.
    Khufu's Avatar
    West coast of Scotland
    5,693
    drive belt off of model without aircon LOL
    larsmate's Avatar
    Apr 2004
    114
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,524
    [ QUOTE ]
    Ross
    [/ QUOTE ]
    Yes, below 5 degrees outside, the compressor won't engage, as it will freeze it solid if it did. You will still be able to defrost the windscreen with the compressor off, the air would be cold enough outside at 5degrees or less, to have any moisture in it. Hope that helps. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    BTW you can replace the clutch mech separately to the compressor. Still fookin' expensive brand new (200), but if you get one from a breakers it'll be cheap and you don't need to open the refrigerant circuit.
    Oct 2005
    uk
    315
    Thanks for the info, need to have a look when it's better weather, need a part number and go from there, not sure if its the comp or the clutch failed atm [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Silly question , does this contain teh clutch too?
    http://cgi.ebay.de/airco-compressor-Audi...1QQcmdZViewItem
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Yeah, if its got the pulley on the end it will have the clutch, which that one has.
    Oct 2005
    uk
    315
    Thanks!
