Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
    Nr. Guildford
    133
    Thumbs down Headlight switch resulting in sidelights on ALL the time?
    Hi,
    The previous owner of my car had fitted front fog lights for show but had also fitted a front fog light switch.
    My OCD wanted the switch gone and the fog lights out for better flow to the intercooler (I know!)
    I got a non front fog switch from ebay but when I fitted it the sidelights are on all the time, even with the headlights off. The warning buzzes with the ignition off too.
    Is the switch faulty or is there more than one type for the A3 8L?
    Thanks in advance,
    Max
    2001 A3 Sport TDi 130 (ASZ)
    Milltek System & Downpipe
    'BlackSmoke' Remap
    Darkside EGR Blank
    CG Motorsport Dual Friction Clutch
    18" RS4 Replica's
    H&R Monotube Coilovers
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    It could be a faulty switch, when my headlight switch went, whenever I turned the headlights on my front fogs would come on too.
    Changed the switch and all ok after that, they are expensive though!!
    Nr. Guildford
    133
    Quote Originally Posted by Nilz View Post
    Looks like I will have to return it to the eBay seller then!
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    Max,
    Make sure the switch is seated properly, I had a similar issue when I had that panel off.
    Hold the front and push firmly from the back of the switch.
    Rob
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Nr. Guildford
    133
    Quote Originally Posted by WorkInProgress View Post
    Max,
    Rob
    As in the plug or the switch in the dash?
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
    Oct 2012
    Scotland
    237
    The actual switch itself
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Nr. Guildford
    133
    I hadn't even pushed it into the dash as the other one was fine whilst out. I've asked the seller for a refund, but will try for the third time to make it work tomorrow.
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
  1. Headlight adjustment motor runs all the time !
    By Cabbyfan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2011, 19:35
  2. econ light on all the time
    By jase0851 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th May 2008, 20:56
  3. second fan on full wack all the time
    By auroan in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th December 2007, 22:47
  4. Pre-facelift door mirrors-heated all the time?
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th August 2006, 12:27
  5. Things that go bump.... all the time !!!!
    By Geronim0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2005, 15:53
