JMB RetrofitsChris Nott
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By westcoast a3
Thread: SFS supersize K03 TIP
    Oct 2012
    140
    So my mapped K03 is getting treated to a THS FMIC next weekend. It currently has a PiperX panel, opened up airbox and Forge TIP. 3" decat on the other side.
    Has anyone gone from Forge to SFS supersize TIP? Its HUGE!!!
    Im wanting to optimisemy K03 to see how much it will safely push. Then move to a K03s later in the year.
    Any user information would be greatly appreciated to see if it's woth the move. Also fitting information would be good. I just managed my Forge!
    Paul
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    I went from CM tip to a SFS one last year. Massive difference with less restriction. Well happy with the results
    <Jay A3 build thread>
    241bhp K03s - R Tech
    Oct 2012
    140
    But how was the fitting? My forge is already bl$$dy tight!
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    Parsons performance fitted it for me. It was tight and just sits on the lines and I've not had one problem
    Nov 2010
    scotland east lothian
    46
    Visit westcoast a3's Youtube Channel
    Have this for a while just need to move/ bend the metal pipe a few mil and sorted
    Oct 2012
    140
    I have no idea how that will fit!
    So would you definitely say it was a bolt on difference?
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    I fitted one to a mates car the other week, it does make a difference and well worth it. But I found it a bit of a pig to fit, I found you can unscrew a a bolt that holds the metal pipe on which will give you some wiggle room, I also found that it was better if you had someone to give you a hand if they fed it from the top and you then guided it into place on the turbo, there wasn't much room but can be done. We also found that a fair bit needed to be trimmed off to get it to fit onto the standard air box, and I'm sure we trimmed a little off when we put the s2000 filter etc on.
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Nov 2010
    46
    All I did was remove air box from
    Top look in take old out metal pip to the right bend down and back offer up if not right bend some more fit tricky part is doing up the screw took fifteen mins lol n am a chef
    s3dave likes this.
    Mar 2014
    Have you got a link to it??? Cheers
    Nov 2013
    108
    Has anyone fitted one over a 3" MAF?
    Ramair filters told me yesterday they wouldn't produce an 80mm version as the market was to small but it would 'probably' stretch over a 3" MAF
    andy68's Avatar
    Jul 2013
    Tameside
    Quote Originally Posted by antwan64og View Post
    Here you go, Ramair are wrong,
    K300 Supersize TIP
    Nov 2013
    108
    Thats for a ko4 compressor housing outlet of 51mm.
    Ko3 housing has an outlet of 45mm.
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,786
    Sfs one fits over the 3" maf fine
  1. How To Fit a K03 TIP
    By A3Tom in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2013, 22:29
  2. Autobahn88 K03 TIP ?
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2011, 22:00
  3. Finally Fitted The SFS Tip & Catch Tank.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2009, 01:30
  4. SFS tip fitting
    By Lacey123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2009, 19:45
  5. New Forge TIP (AWW one) on AGU with K03s
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2009, 14:00
