JMB RetrofitsVolks Autos
Results 1 to 9 of 9
Thread: Abs light on
    Richierich84's Avatar
    Feb 2014
    Rainham
    20
    Abs light on
    Hi peeps got my abs light on 2000 s3 Iv tried them out by stamping hard on the breaks none lock up and stops nicely any ideas
    Mar 2014
    15
    Possible loose abs sensor on brake pads m8
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,554
    Have you scanned for fault codes? if a light is on then there will be a fault code in the ABS module... no point in guessing what the problem is when a fault code will help you diagnose the issue
    <tuffty/>
    Feb 2014
    Rainham
    20
    Will check them all out tomorrow are they on all breaks or just fronts ??
    Feb 2014
    Rainham
    20
    Haven't got a fault reader would mean taking to a garage
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    Click the link in my signature (vcds map) for members on here with vcds cables in your area
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,554
    Quote Originally Posted by Richierich84 View Post
    Well have a read of this and get the software and cable for around a tenner
    IMPORTANT! - When posting asking for help... - PLEASE READ BEFORE POSTING (UPDATED)
    ...or look on the VCDS section and see if there are any willing members near you that would scan the car for you..
    VCDS (formerly VAG-COM) forum
    ...or take it to a garage and the can scan it for you...
    Either way there will be a code in the ABS module and it will help you (if not tell you outright) why the light is on...
    Guessing will not help and potentially end up costing you more as you replace bits you think is wrong... these cars have control modules all over them and the all store fault diagnostic codes when a fault occurs
    <tuffty/>
    Feb 2014
    Rainham
    20
    Quote Originally Posted by Sandra View Post
    Thanks for them
    Feb 2014
    Rainham
    20
    <tuffty/>
    Thanks for the advise tuffty
