EM TuningJMB Retrofits
Results 1 to 12 of 12
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Cross threaded rear suspension bolt hole help.
    Hi guys,
    As title suggests, I recently changed my rear dampers on my S3. Its seems that the passenger side bolt hole on the trailing arm has only got a couple of threads useable which the bolt just cant get a bite on.
    Would I be best buying a 2nd hand trailing arm off of ebay or will this repair kit do the job?
    25714030000 | AMAFASTENERS Ltd. (UK)
    My main question with the kit is the fact it states for M14x1.5 when the bottom bolt is M14x1.
    All advice and opinions welcomed
    Matt
    A3 TQS
    Jul 2013
    Devon
    163
    It is M14x1.5 if this is the bolt your referring too, No.5 in this picture AUDI A3/S3/SPORTB/QU. [A3] (MEXICO) 2001: REAR AXLE: 51115. SUSPENSION; SHOCK ABSORBERS
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Thats the bolt im having diffs with. I must of read the type wrong. Do you think that kit would do the job?
    Matt
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    drill through and use a longer bolt with a nut
    A3 TQS
    Jul 2013
    Devon
    163
    I've used plenty of helicoils, but usually for replacing knackered threads in aluminium and never on anything critical like that so wouldn't like to say, If drilling through and using a locking nut is an option, then I'd be happier with that I think.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    I've had to use a nut and bolt on one side of mine.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Feb 2006
    Lincolnshire
    719
    Just get a longer bolt and nut, you won't need to drill it.
    The only thing you need to worry about is making sure it's at least a 10.8 HT bolt (and nut) and you can always cut it down if it's too long.
    I've had to do my passenger side too.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Cheers for the replies, i have ordered a couple of 100mm and 110mm bolts with some nylock nuts.
    Would you recommend using some loctite as a precaution?
    Matt
    Oct 2012
    429
    no need for loctite the nyloc nut will be fine
    Jan 2011
    86
    HI Matt ,
    Just read your post . I had the same problem when fitting my B8's managed to cross thread the hole , resolved it to , by using
    the same bolt from the other side of the hole . Clean the threads up first with a thread file and plenty of squirt and it can be wound in
    from the back , go slow and draw the bolt in and out a few times . Giving you a clean thread to start again . All assuming the bolt is'nt too dammaged . Or could be done with a new bolt . Good luck
    Cheers Ant
    Jan 2011
    86
    You'll also need to whip the caliper and carrier off that side for better access , but it is do able
    MattW86's Avatar
    May 2009
    Norn Iron
    74
    Cheers for the replies guys, Ant i might give that a try while im waiting for the longer bolts to arrive.
    Matt
