EM TuningChris Nott
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By kwistof
Thread: Audi s3 8l exhaust rattle from downpipe help?
    Mar 2014
    I have recently fitted a relentless down pipe and decat and it has started to vibrate and rattle really loudly when I come off the accelerator any one know what could be causing this?
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    456
    I've heard a few of them have been knocking on the prop-shaft... What does clearance look like down there?
    Mar 2014
    Not to sure ill have to have a look at it tomorrow as I'm at work now but its only come on since I properly supported it on the hanger before it was fine
    Aug 2011
    Plymouth
    762
    Add Lavis89 on Facebook
    Mine used to rattle a lot when I was pulling away, put on a powerflex bush on the dogbone mount, solved my problem
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Vent pod boost gauge, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave (RIP) adjustable tie bars, FMIC
    Soon to be done: SAI delete, 3" Catback, Stage 2 remap
    Mar 2014
    I've just bought one will be here tomorrow thanks
    Crazypete00's Avatar
    Oct 2007
    266
    did you sort the rattle out? think mine is doing it on the subframe. happens when im reversing and letting off, so guessing its when the engine moves forwards on its mounts
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    Quote Originally Posted by Crazypete00 View Post
    I have exact same problem.
    I beleive powerflex (or any solid) engine mounts would reduce the engine movement and by doing so, reducing the chances of the downpipe knocking on anything next to it. The clearance is tight
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    If only this had been discussed before
    Downpipe results in replacing my engine mounts
    <tuffty/> likes this.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Oct 2007
    266
    thanks kwistof, i did do a seach last night and spent about an hour going through old threads.
    so loosening the engine mounts and pushing it over as far as it goes to the passengers side is worth a shot before replacing the mounts then.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    No worries- I have pointed that thread to at least half a dozen people just in the past month tbh! lol
    That's definitely the first place to start, be it the cheapest/easiest/quickest option- as you can see in that thread that didn't work for me unfortunately but as soon as the engine mounts were replaced I haven't heard a knock/bang since and I give my car a good thrashing at times
    2000 S3 APY
    Oct 2007
    266
    thanks again. if you know any mods that can possibly add little bits of info like this to the sticky's. there is a sticky about the xs power DP and cat so adding something like this on the end would be great.
  1. AUDI A6 C7 HEADLIGHT UPGRADE FROM HALOGEN TO BI XENON **HELP NEEDED**
    By A64GGuy in forum A6/S6/Allroad forum (C7 Chassis)
    Last Post: 2nd November 2013, 00:27
  2. audi 2.5 tdi s line smokeing from cold help
    By fast2loud in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th December 2012, 19:35
  3. audi a4 avant exhaust trims In Black With Out Cut Outs Please Help Me
    By sam_a4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th March 2008, 11:43
  4. New A3 Rattles from Windows/Door Seals
    By skyblue11 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2006, 21:28
  5. Who's had the wet exhaust rattle modification?
    By JaGermanCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2003, 10:23
