AEB large port head on BAM engine??
S3 Hilife
It's an addiction
Wisbech, Cambridgeshire
Why would someone fit an AEB head on a BAM engine block?? I have owned my S3 for a good few months now and only just noticed it has AEB stamped on the head, The data badge in the boot has BAM 225, the AEB is a longitudinal engine with a measly 150bhp, I know my S3 had a Revo stage 1 before I bought it, I have good power from the engine and around 1.3 bar of boost. I dont know how I missed this when I bought the car but I'm a little confused as to why its not a BAM head,
Is there something that i'm missing?
Because its a large port head where the BAM head is a smallport... large port heads are better for top end power, but small port heads are better for low down torque...
Small port heads are fine for 350hp but if going for a a larger framed turbo then large port is better...
I would imagine the previous owner spent too much time on forums and fitted the AEB to gain power (which is not as much as you would think on a K04) or the belt snapped, bent valves and this was a replacement based on reading forums and thinking it would be a better bet...
Doesn't matter that the AEB is longitudal... the castings for the head are the same....
<tuffty/>
Thanks for the response, so It may not be as bad as I thought, depending on its past history of course, I know it had already had some mods done before I bought it but I was starting to panic a bit,
Is this a fairly common mod on the BAM engine?
Its a common mod on any 20v engine tbh... but normally more for the bigger turbo boys... large port head is also found on the AGU A3's...
<tuffty/>
Happily swap it with my standard BAM head as I have a BT going on soon ;)
I think i'm going to have a closer look at my engine at the weekend and see exactly whats going on,
Thanks again for the help
707
10
2K
7
13
HTC
